MAYTAG MSD2652KES
3 replies to this topic
#1 deanfaw1
deanfaw1
    Yamabushi
  • Master Appliantologist
  • 79 posts
Posted 11 January 2012 - 03:19 PM
This unit is frosting up on the evaporator coils from top to bottom. The heater works because I used the voltage from the light bulb connectors to turn it on and defrost. The defrost thermostat works because it has continuity. So I swapped out the defrost board. 1 month later the same thing. Why me? I'm thinking freezer control. Because the damper at the top was wide open so the cold control should be fine. I asked the customer if the unit runs continuously and she doesn't think so.
#2 jumptrout
jumptrout
  • 1,380 posts
  • Flavorite Brew:Coors Light
Posted 11 January 2012 - 05:40 PM
The adaptive defrost control adjust to refrigerator door open use.
To test the ADC and heaters,access the ADC.
Place a amp meter over one incoming power wire on the power supply cord.
Make a small insulated jumper wire and jump L1 to Test terminal.
This will initiate defrost.
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 January 2012 - 05:47 PM
...Make a small insulated jumper wire and jump L1 to Test terminal.
maybe not on that model number...
first try:
To Force Defrost: Turn cold control on and off 3 times within 6 seconds.
#4 deanfaw1
deanfaw1
    Yamabushi
  • 79 posts
Posted 11 January 2012 - 06:49 PM
Thanks I will try this unit is so basic that it's frustrating. But I will try cold control test Here is the wiring diagram. http://c.searspartsd...05074-00018.png
Edited by deanfaw1, 11 January 2012 - 06:50 PM.
