Admiral washer AW20N2V sometimes takes beer break mid cycle....timer?
5 replies to this topic
#1 seabass
seabass
  • 3 posts
  • Flavorite Brew:cold
Posted 11 January 2012 - 08:30 PM
Admiral washer AW20N2V sometimes takes beer break mid cycle....timer? Can hear clicking sometimes, switch timer off and on helps sometimes, sometimes just wait and most times will finish
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 January 2012 - 10:36 PM
... sometimes just wait and most times will finish
will it start back up by itself ?
Does the Timer Motor run when it's "on break" ?
#3 seabass
seabass
  • 3 posts
Posted 12 January 2012 - 07:53 PM
yup, most times starts back up by itself.
yup, timer motor runs when it's "on break"
    Shōgun
  • Master Samurai Tech
  • 30,532 posts
Posted 12 January 2012 - 07:59 PM
Sounds like the motor is overheating and kicking out on thermal overload until it cools enough to auto-reset. Can verify by making a voltage measurement at the timer pins that supply power to the motor or at the motor itself.
Here's the part link for your washer motor, pick based on whether your model is two speed or single speed ==> http://www.repaircli...680-Motor-Parts
#5 seabass
seabass
  • 3 posts
Posted 19 January 2012 - 08:23 PM
ok. i haven't done voltmeter check yet, but now it ran until the timer cycle ended but tub was still full of water. had to rerun spin to drain
#6 RegUS_PatOff
  • 33,588 posts
Posted 19 January 2012 - 08:39 PM
... Sounds like the motor is overheating and kicking out on thermal overload
then Timer Motor wouldn't continue on that model,
(reason for my previous question)
