Kenmore (110.66702690) 70 Dryer Won't Heat... still after the usual checks and fixes
heat problems
6 replies to this topic
#1 bikechain
bikechain
  • 2 posts
  • Flavorite Brew:Bell's TwoHearted
Posted 11 January 2012 - 08:57 PM
I have replaced the thermostats and switches (in heat duct) and next to the blower motor. I have checked that each thermostat and the the thermal fuse have continuity and power (240). No obstructions and breaker is fine. Still no heat. Could it it be the timer? Any other ideas. Thanks,Kent
#2 jambatt
jambatt
    Senpai
  • Scholar of Appliantology
  • PipPipPipPip
  • 894 posts
Posted 11 January 2012 - 09:20 PM
If drum does not turn, check door switch.
Don't take life too seriously, none of us get out alive !
#3 RussTech
RussTech
    Kohai
  • Master Appliantologist
  • 309 posts
  • Flavorite Brew:Heineken
Posted 11 January 2012 - 09:26 PM
Dumb question, but does the element have continuity?
Edited by RussTech, 11 January 2012 - 09:27 PM.
#4 phydeauxe64
phydeauxe64
    Sōhei
  • 104 posts
  • Flavorite Brew:"Double D" Turbo Coffee
Posted 11 January 2012 - 09:28 PM
Is the heating element ok? Did you check it for continuity,check it for ohms? What is the voltage at the back of the dryer? Should be 240vlts You said the breaker is ok, did you check the receptacle? Turn off breaker to dryer and try checking the wiring at the receptacle. Part link ==> Part number: AP3094254
Edited by Samurai Appliance Repair Man, 12 January 2012 - 07:26 AM.
Edited part link using the yellow APP button in the editor tool bar to make it affiliate-able.
#5 bikechain
bikechain
  • 2 posts
Posted 11 January 2012 - 09:40 PM
The drum turns, and the ducts blow. The element has continuity. The wire block at the top of the dryer reads 240 volts.
#6 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 January 2012 - 10:28 PM
wiring diagram not listed at S/M
Set the Dryer for a Heat Cycle,
Open the Door and (remove Drum if needed)
Measure for 120v AC between each side of each Thermal device, to chassis (ground)
#7 phydeauxe64
phydeauxe64
    Sōhei
  • 104 posts
Posted 11 January 2012 - 10:33 PM
Did you check voltage from L1 to N and L2 to N each should read 120VAC Then from L1 to L2 you should get 240Vac. If you have voltage there I would check voltage coming from motor to element.
