GE PFS22sbsbss Fridge. DOA
12 replies to this topic
#1 kettlehill
kettlehill
  • 4 posts
  • Flavorite Brew:Dos Equis Special Lager
Posted 15 January 2012 - 07:58 AM
Yesterday the refridgerator died. No cooling at all. Unplugged, plugged. Turbocool. Nothing except periodic clicking. Fan near coils does not move.I removed lower rear panel and vacuumed: a bit dusty and funky but no ice, water. Fortunately,here in Vermont it is presently 2 degrees F, so with six coolers on porch we are OK for now, but....Research tells me it is the motherboard, but what about the fan? Heard tell of GE replacing free?
Drink Vermont Beer: Long Trail, Otter Creek, Magic Hat!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 15 January 2012 - 08:18 AM
depends on full model number
and first 2 characters of serial number
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 15 January 2012 - 10:36 AM
The clicking is either the board or the start/relay. If you can localize the sound, then that is probably the part needing replacement. You can also access your board, disconnect fridge and on the board jump "line" (or "l1") and "comp." You will find this at the main power connection on the board. It's the connector that's connected horizontally and has three large pins, usually marked "comp", "defr" and "line". The outer two are the ones you need to jump. Do not remove the connector. Now reconnect fridge. If the compressor comes on after a few minutes, replace the board. If you continue to hear the click, it is more than likely your start/relay or worse case scenario... compressor itself.
Edited by DurhamAppliance, 15 January 2012 - 10:41 AM.
www.DurhamApplianceThrift.com
#4 kettlehill
kettlehill
  • 4 posts
Posted 15 January 2012 - 11:11 AM
it does sound like a relay, the way it clicks. Assuming the relay is on the board, does that mean iyt is necessary to replace the whole board, or just relay. Compressor sounds right, humming along, just does not cool. Thank you for your help.
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 15 January 2012 - 11:56 AM
Board clicking and compressor running but fan not running doesn't sound right. If you are certain your compressor is running ( is it warm and vibrating?) and your compressor fan is not running, then you either have a bad fan motor or a bad board. Boards are not usually serviceable unless you are good with trace soldering and transistor replacement. btw are the sides of the fridge near the front hot to touch?
Edited by DurhamAppliance, 15 January 2012 - 12:00 PM.
#6 kettlehill
kettlehill
  • 4 posts
Posted 15 January 2012 - 01:29 PM
the fan that is not working is lower left rear (looking from front) positioned to blow on coils. Is there another fan?
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 15 January 2012 - 03:23 PM
There should only be one fan accessible from the rear of the fridge but we are unable to get accurate schematic as there are 28 different
pfs22 models. That's why it's a requirement to post ENTIRE model numbers . Numbers from a manual or advertisement sticker isn't sufficient. http://www.repaircli...My-Model-Number
#8 kettlehill
kettlehill
  • 4 posts
Posted 15 January 2012 - 03:32 PM
PFS22sbsbss
serial #ZL046043
Thanks for help
#9 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 15 January 2012 - 07:22 PM
Edited Title
#10 RegUS_PatOff
  • 33,588 posts
Posted 15 January 2012 - 09:45 PM
PFS22sbsbss
serial #ZL046043
Service Bulletin covers that model,
but only for May 2005 - Jul 2006
not your serial ZL = Dec 2006
MotherBoard
Evapoprator Fan
Dispenser Board
#11 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 16 January 2012 - 12:42 AM
but not your serial ZL = Dec 2006
http://www.youtube.com/watch?v=oPwrodxghrw&feature=youtube_gdata_player
#12 phydeauxe64
phydeauxe64
    Sōhei
  • Chief Appliantologist
  • 104 posts
  • Flavorite Brew:"Double D" Turbo Coffee
Posted 16 January 2012 - 11:53 AM
If you hear a clicking sound coming from back of fridge 9 outta 10 times it's the main board the relay that engages the comressor on the board usually goes bad rplace the board and yer troubles are over. Main Control Board
Edited by Samurai Appliance Repair Man, 16 January 2012 - 04:34 PM.
Edited part link.
#13 RegUS_PatOff
  • 33,588 posts
Posted 16 January 2012 - 01:21 PM
"... missed it by that much..."
actually means you already have the "new improved" MotherBoard,
although they could still go bad...
