LG WD-80160F frond load washing machine wont spin, on QC test Spins FINE!
Started by mxp, Jan 16 2012 03:33 AM
lg spin problem wd-80160f spin pwb
1 reply to this topic
#1
Posted 16 January 2012 - 03:33 AM
Hi everyone,I will try to explain my story..
Well my LG WD-80160F washing machine problem is :
At any program when its time to pass into spin procedure, it does not spin (till then all the function are working fine)...
Only it tries to spin (speeding up for 2-3seconds) and then go back to normal right-left turns..
after a while tries again and then the same..
So the choosen program never go to END..tha draining pump works all time...and no error shown up..
I get the service manual and made some tests.
On QC test Spins FINE at 400rpm . 600rpm and 800rpm..!
here is the manual
I have already check these:
1.Drum spider
2.motor brushes
3.door lock (not yet 100% completed, can i test it direct in main voltage to see if its working??)
4.Cable connections.
5.Pcb inspection (I tried to find a new part to see the price but there is nothing for sale, even from LG )
6.Drain pump
7.Heater
8.Inlet pump
Next step : I will also remove the belt and check if it spins.. (maybe the belt is too tight)
I have read also many post fro similar issues..
It may be the PCB..I dont know..
Anyone had before the same problem??
Thanks a lot for your time..
Waiting for yours opinion.
Maybe late i post some pics..
Manos
here is the manual
1.Drum spider
2.motor brushes
6.Drain pump
7.Heater
8.Inlet pump
Manos
#2
Posted 22 January 2012 - 02:29 PM
Are you using HE detergent? If so, how much? More than a Tablespoon?
Could just need to be cleaned out...
Have you ever cleaned the machine?
Do you use "HOT" wash periodically?
www.eliteapplianceservice.org
Also tagged with one or more of these keywords: lg spin problem, wd-80160f, spin, pwb
