Caloric Prestige Series Range RST399UL - knobs won't push in or turn
10 replies to this topic
#1 OKNYC
OKNYC
  • 6 posts
Posted 17 January 2012 - 04:49 PM
My Caloric Prestige Series stove oven combination has two control knobs that don't push in and don;t turn - and thus they don't pass gas and won't light. The other knobs are working - electronic ignition.
The upper and lower ovens start up well also - though I could probably install new lighters - they do glow but take a while.
But the knobs that don't turn - can I fix them? WD40? Or some maintenance treatment?
They actually don't push in as they should and don't turn.
Dean
#2 kdog
    RoughShod
  • 7,433 posts
Posted 17 January 2012 - 07:54 PM
Try swapping the knobs with one that works, perhaps the knobs have stripped out.
Ten Commandments for Reading Appliance Model Numbers :)
#3 OKNYC
OKNYC
  • 6 posts
Posted 17 January 2012 - 08:20 PM
I have pulled the knobs off and I can't get the stem to move without the knob. I suppose I need new valves?
#4 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 17 January 2012 - 08:32 PM
Yes you need to replace the valves.
Give us a model number and we will give you the valve number.
#5 OKNYC
OKNYC
  • 6 posts
Posted 17 January 2012 - 08:36 PM
Ok. I am not with the stove now. I will look for the model number - it is a Prestige Series with a lower and upper oven - fairly large unit. Where will I most likely find the model number?
#6 kdog
    RoughShod
  • 7,433 posts
Posted 17 January 2012 - 10:38 PM
The stem needs to push inward prior to turning - try it with a known good knob
#7 OKNYC
OKNYC
  • 6 posts
Posted 17 January 2012 - 10:55 PM
I tried that. I swapped knobs many ways.
#8 Budget Appliance Repair
  • 4,032 posts
Posted 18 January 2012 - 06:43 AM
Moisture and crud build-up around the surface burner gas valve shafts will cause the shaft to lock up solid.
If they have the same valve as other Calorics and other brands that use the same style of valve you can take the two screws out of the shaft and front plate on the valve to remove the knob shaft and valve front cover and can sometimes if they aren't to badly fouled get them to turn again by spraying with WD40 or other penetrating fluids.
If you can get the shaft to start turning and clean the shaft so you can pull it out of the front plate then you can lube the shaft where it turns in the front plate with silicone valve grease to keep it turning smooth and from freezing/locking up again.
William Burk (Willie)
Eureka, CA 95501
#9 OKNYC
OKNYC
  • 6 posts
Posted 18 January 2012 - 12:40 PM
The model is:
AMANA
RST399UL
And serial number 9608305621
#10 jumptrout
jumptrout
  • 1,192 posts
Posted 18 January 2012 - 01:15 PM
http://www.repaircli...Number=RST399UL
#11 OKNYC
OKNYC
  • 6 posts
Posted 30 January 2012 - 08:09 PM
How do I get at the valves? My model stove has the upper oven hanging over the range and the lower oven. The gas burners are sealed - range top does not lift up. I undid some screws on the face plate that surrounds the burner valves but could no get the face plate off - there is a screw under the range to that holds the corner end pieces of the face plate on. Looks like I got to at least loosen the range top - really quite a bit of dismantling it seems.
What's the low down here - how do I get at the burner valves to replace them?
Thanks.
