not cooling Kenmore 596.57542791
8 replies to this topic
#1 llky
llky
    Sōhei
  • Chief Appliantologist
  • 175 posts
Posted 18 January 2012 - 05:10 PM
My Kenmore side by side refrigerator model 596.57542791 is not cooling. The compressor is running I checked the freezer and it was frosted on the back wall.The evaporator fan was not running.I took off the back panel and the evaporator was frozen up.I turned the defrost timer into the defrost cycle and the defrost heater comes on.I then turned the timer into the refrigeration cycle and the evaporator fan came on.I'm thinking that the evarorator fan should be running when the compressor runs.Is this right?Also what would have made it freeze up?
#2 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 699 posts
Posted 18 January 2012 - 07:00 PM
From your description it sounds like you have a faulty defrost timer. Did you let the timer complete the defrost cycle?
  • 24,721 posts
Posted 18 January 2012 - 08:02 PM
Part link to the defrost timer ==> http://www.repaircli...er=596.57542791
#4 llky
llky
    Sōhei
  • 175 posts
Posted 18 January 2012 - 08:33 PM
Thanks for the replies.No I did not let the timer complete the defrost cycle.What about the evaporator fan?Should it be running when the compressor runs?
#5 RegUS_PatOff
  • 30,708 posts
Posted 18 January 2012 - 08:52 PM
... evaporator fan?
... Should it be running when the compressor runs?
not always,
I think only when the Defrost Thermostat is cold again (closed) after Defrolst.
Kenmore 596. made by Amana
I'm trying to find a wiring diagram...
  • 24,721 posts
Posted 18 January 2012 - 10:44 PM
not always,
Correctillia.
And what is that temperature in the freezer?
#7 RegUS_PatOff
  • 30,708 posts
Posted 19 January 2012 - 12:41 AM
OR, it coul;d just be a bad Evaporator Fan.
Is there 120v there ?
#8 llky
llky
    Sōhei
  • 175 posts
Posted 19 January 2012 - 04:10 PM
Yes there is 120 volts at the evap fan.Should it always be running when the compressor is running?
#9 RegUS_PatOff
  • 30,708 posts
Posted 19 January 2012 - 04:30 PM
should be running if there's 120v at the Evaporartor Fan Motor
Only runs [when the Compressor is running and the Defrost Thermostat is closed (cold)]
