amana sxd26vw
2 replies to this topic
#1 tommytech
tommytech
    Sōhei
  • Appliantologist
  • 176 posts
  • Flavorite Brew:guiness
Posted 20 January 2012 - 06:12 PM
Here's a good one for ya.tech was out yesterday and repaired cracked plastic tubing causing leak.stop cooling sometime after techleft. the evap fan does not run,no frost /warm evap coil,cond fan runs ,comp running.he said he either moved the foam strip in the back to acess leak. w t f??
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 20 January 2012 - 07:57 PM
Amana = Evaporator Fan won't run until Evaporator is cold (Defrost Terminator closes)
Any frost on Evaporator ?
#3 tommytech
tommytech
    Sōhei
  • Appliantologist
  • 176 posts
Posted 21 January 2012 - 09:04 AM
tapped the system-running in vacuum,no frefrigerant.after much digging,i renoved what was left of some rodent chewed insulation,removed that and one of the copper lines was sitting almost completly in the drain pan and was all corroded-leak was right there. time for new box for those folks.
