Kenmore 800 Series Model 110.29822800 Washer Agitation Problem
5 replies to this topic
#1 appliancejack
appliancejack
    Sōhei
  • 153 posts
  • Flavorite Brew:Bud Light
Posted 20 January 2012 - 07:48 PM
Hello Forum:
It's been a while since my last post. Happy New year to everyone. This washer starts off in most of the cycles with a real fast agitation and water starts spraying after about a minute. It seems to take a while to fill with the water coming on and then off through-out the cycles and the agitation seems to finally sound like a normal agitation. It just starts off agitating real fast and balling the clothes up before any water falls. I was under the impression that the tub should fill some before agitation should begin. Reading through some of the forums, its pointing to the pressure switch or the timer. The timer seems to run through all cycles, however the water is on and off. I would appreciate any input.
Thank you
Jack
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 20 January 2012 - 08:02 PM
sounds like a common problematic Pressure Switch
http://www.repaircli...R=154&N=1550760
#3 phydeauxe64
phydeauxe64
    Sōhei
  • Chief Appliantologist
  • 104 posts
  • Flavorite Brew:"Double D" Turbo Coffee
Posted 20 January 2012 - 08:16 PM
Sounds like the contacts in the pressure switch are stuck. the contacts have to make in order for the washer to go into agitate. If its agitating before water is in tub this could be yer problem. Try replacing the pressure switch part# Part number: w1029284
#4 appliancejack
appliancejack
    Sōhei
  • 153 posts
Posted 21 January 2012 - 09:22 AM
OK I'll give this a try. I will let you know. Thank you very much.
#5 appliancejack
appliancejack
    Sōhei
  • 153 posts
Posted 02 February 2012 - 10:49 PM
I almost forgot you are absolutely correct with your suggestion. God Bless you Great Wise One.
#6 RegUS_PatOff
  • 33,588 posts
Posted 02 February 2012 - 11:03 PM
"This Bud's for you" :pint1:
