model kenmore 600 type 111-05 makes noise
20 replies to this topic
#1 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 21 January 2012 - 06:50 PM
washer makes noise during the spin cycle, like an unbalanced load? it does it all the time so im not sure its unbalanced
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 21 January 2012 - 07:15 PM
model number ?
#3 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 21 January 2012 - 07:37 PM
type 111-05 ser co1440750? know it says kenmore 600??
#4 RegUS_PatOff
  • 33,588 posts
Posted 21 January 2012 - 07:59 PM
model number ?
#5 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 22 January 2012 - 12:09 PM
ok here it is Model: 110.29622801
sn: Co1440750
the agitator drum seems to move around quite a bit(statically) by grabbing the agitator and just moving the drum around. i could see it making noise with it moving so far around. where do I start? thanks:)
#6 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 22 January 2012 - 12:35 PM
Lean the machine back and make sure the counter
balance spring is in place.
#7 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 22 January 2012 - 12:42 PM
yes its there intact this unit is maybe 4 years old?? I did adjust the front legs a bit. said the front was low still good from side to side
#8 certified tech group 51
  • 2,704 posts
Posted 22 January 2012 - 12:45 PM
As the unit is tipped back as per Appl. Techs' instructions look for your two sets of pads....One set on top of the suspension plate and a set that the suspension plate sits on ( suspension plate, a triangular piece looking gizmo, a technical term .. )....one of the pads could of got knocked out during a violent spin cycle....
#9 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 22 January 2012 - 12:47 PM
do u have a pic of what im looking for/ is it obvious/
#10 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 22 January 2012 - 01:08 PM
i looked under washer the entire motor agitator assembly rotates or glides all over the place. I do not see any loose or missing springs and I see 3 areas that might have a white nylon? bushing that it glides on. the two tangs are pushed through on all 3? also , wouldnt i see the bushing if it fell out?
#11 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 22 January 2012 - 01:24 PM
make sure the suspension plate is not twisted around..this will cause violent shaking durng spin.
this is usually caused by layng the machine down or transporting improperly.
#12 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 22 January 2012 - 01:38 PM
i leveled the machine front to back and side to side. the front legs were loose and the jam nuts were loose too. tightened nuts after adjustment. im not sure what you mean by twisted around but the washer has been fine for 2 years or so and just started acting up. I do not see any springs disconnected or missing or bushings either ( i may not be seeing it correctly) but I think I am. I see all 3 sets of white bushings at least the two nubs that stick down through?? all 3 springs are hooked up and the counterbalance spring as well. Does this machine have some kind of inertia switch? or switch for when its in spin based on rpm and load etc??
#13 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 22 January 2012 - 01:45 PM
whats the procedure to replace these pads? say if they are worn which you cant really see until you take them out . im about to run a load and see if balancing the legs reduce the noise
#14 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 22 January 2012 - 01:55 PM
there is no out of balance switch on this machine. if you see 3 sets of nubs sticking through (tan or brown in color usually) then your damper
pads are probably ok. If they were missing you would see black residue on the support legs from metal on metal contact.
A video would be great if you could post one.
#15 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 22 January 2012 - 02:34 PM
they r white. it spins fine. I just ran a load through the noise happened during the rinse cycle(i think from the wash cycle) there was a boom boom boom for about a minute or so then never again. not sure what else to do. I do see 3 sets of nubs(white) what could it be that allows it to make that noise during the rinse cycle? the drum is spinning during this cycle but its in thee rinse cycle before the actual spin cycle
#16 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 22 January 2012 - 02:39 PM
just finished the wash ands it made the same noise at the very end for about 30 s or so. then it shut off all done. is this speed dependant? this was the spin cycle after only doing 1 rinse cycle. ????? cant be normal
#17 certified tech group 51
  • 2,704 posts
Posted 22 January 2012 - 05:30 PM
When the unit is in the spin cycle, lift the lid...Does the spin basket stop within 3 to 4 seconds, or does it keep spinning, then slows down and banging ???
#18 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,098 posts
Posted 23 January 2012 - 07:39 AM
I would be willing to bet this is what is happening, the classic stripped drive block........
William Burk (Willie)
Eureka, CA 95501
#19 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,954 posts
Posted 23 January 2012 - 09:55 AM
Drive Blockology 101:
Buy the replacement drive block here ==> http://www.repaircli...858&PartID=2858
You'll need this spanner wrench to get the inner basket out ==> http://www.repaircli...21707&PPStack=1
#20 jwj2357
jwj2357
    Yamabushi
  • 86 posts
Posted 12 February 2012 - 09:42 AM
ok I can try this. i believe it runs much longer than 3-4 s before it shuts down. the video attached is for this model as well?
