Whirlpool WFW9300VU02 - Major rattle during spin cycles
3 replies to this topic
#1 kavadon
kavadon
    Ikkō-ikki
  • 40 posts
Posted 22 January 2012 - 12:15 AM
Hi all, quick question for the knowledgeable masses....
Whirlpool front loader... bearings failed after 2 yrs of use. I replaced bearings and seal in Aug, 2011. Within one month after that, a noticeable rattle appeared in low and medium speeds during spins in the wash cycle. It appeared the noise was coming from the inner tub banging against the outer plastic housing after watching the shocks with front kick panel off (plastic housing was not hitting the inside of the main unit shell). Ok, perhaps one of the replaced bearings was faulty.....
I replaced the bearings and seal again 2 weeks ago with parts from a different source this time. Same problem with the rattle appeared after a couple of loads so I'm fairly certain it's not so much the replaced parts, but the question is what is running out of round during those spin cycles?
I've taken the back plate off and watched during the spin cycles. I see the pulley wheel running out of round a bit to cause the noise. Belt and motor looked fine. Curious if it's possible to have tightened the shaft nut too much during the first repair (and damaging the pulley since it looked like cast aluminum or powdered metal) or somehow I've bent the spin shaft on the inner tub? I did have to tap the shaft loose from the seized bearing in the first replacement.... so curious if anyone thinks it's the puller or the shaft on the tub.
Anybody else seen this before?
Edited by kavadon, 22 January 2012 - 12:24 AM.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,892 posts
  • Flavorite Brew:Killians Red
Posted 22 January 2012 - 01:58 AM
If it was siezed badly enuff that ya had to beat it out...prolly need a new basket/shaft assembley.
Where did ya get the bearing/ seal? This is only officially available with the entire rear tub...
If you are extracting/replacing just this part from a non-OEM source, this could be the issue...
#3 kavadon
kavadon
    Ikkō-ikki
  • 40 posts
Posted 24 January 2012 - 10:56 PM
Hi, sorry for delay. Was out of pocket with work for a couple of days.
Kurtius, thanks for the reply. No - it was not the original assembly from the factory for the replacements. Wish I was rich enough to afford that (especially twice), but I'm just a poor working stiff trying to get by. Yes, the original teardown did need me to tap on the driveshaft with a block of wood to bust the seized bearing loose from the shat, so I suspect that might be most or all of the problem.
Next replacement will be to also replace the tub I guess. If that does not correct this, then the monster will be put out to pasture. At that point it would have been cheaper to buy a new machine and take my chances.
Thanks.
Edited by kavadon, 24 January 2012 - 10:58 PM.
#4 nickfixit
nickfixit
  • 2,195 posts
  • Flavorite Brew:Glen Livit
Posted 26 January 2012 - 06:18 AM
I don't know how a person could get the proper bearings and seal for these. Whirlpool does not make them available apart from the tub, and I don't see how a person could pick generic bearings of the right quality. If the factory water seal isn't available, what did you use?
0 members, 1 guests, 0 anonymous users
