Frigidaire GLTF2940ES3 runs and drains, but won't spin
GLTF2940ES3
7 replies to this topic
#1 TomB985
TomB985
  • 5 posts
Posted 22 January 2012 - 04:04 PM
Hey everyone,
Real new to this site and hoping someone can point me in the right direction. I have a Frigidaire Gallery frontloading washer that was purchased in May of 2007 that just stopped working right today. It seems to go through the cycles fine, but when it comes to the drain/spin cycle the pump comes on, water comes out the hose, but it will not spin.
Trying to troubleshoot, I placed it on the "Rinse/Spin" setting and watched it go through a typical rinse cycle where it tumbled the clothes through clean water. When it went to drain the drum stayed stationary while the pump removed what water it could. What could prevent my washer from performing a proper spin cycle? Thanks in advance to any replies!
#2 RegUS_PatOff
  • 30,278 posts
Posted 22 January 2012 - 04:20 PM
While it's in the Spin cycle, is the Door locked?
Is it really lolcked ?
If so, then unplug the Washer Power Cord from the Wall Outlet.
Can you then open the Door right away ? (bad Door Latch Assembly)
OR only after a few minutes ?
http://www.repaircli...R=154&N=1531974
Door-Switch-Assembly-131763202-01235823.
#3 TomB985
TomB985
  • 5 posts
Posted 22 January 2012 - 04:34 PM
Interesting...I just went down there and checked. When I start the "Drain/spin" cycle the door locks, the light comes on for "door lock", and I can't pull it open. Without shutting it off I pull the power cord and the door opens when I pull it. Is this not supposed to happen?
Why wouldn't a properly functioning door latch assembly behave like this?
#4 RegUS_PatOff
  • 30,278 posts
Posted 22 January 2012 - 04:36 PM
.. Can you then open the Door right away ? (bad Door Latch Assembly)
#5 TomB985
TomB985
  • 5 posts
Posted 22 January 2012 - 04:39 PM
So 'cause I can open it right away after I unplug the washer that means that it's bad? Interesting...
What causes these to go bad? Also I found the part for cheaper off of another site, is the one you linked to related to this site any? If so I'll purchase it from the one you linked to, as this is an AWESOME site!
#6 RegUS_PatOff
  • 30,278 posts
Posted 22 January 2012 - 04:50 PM
... So 'cause I can open it right away after I unplug the washer that means that it's bad?
... What causes these to go bad? ,
... is the one you linked to related to this site any?
1) yes
2) yes, there's some (thermal) / Switch / inside the assembly
3) yes
#7 TomB985
TomB985
  • 5 posts
Posted 22 January 2012 - 04:59 PM
Just ordered it, will post again when I have it back together! THANKS!!! :thanks:
#8 TomB985
TomB985
  • 5 posts
Posted 28 January 2012 - 10:01 AM
Okay, so I ordered the parts through the links above, I have it back together and it WORKS!  Many thanks to all who helped, this site rocks!
