Jenn Air JER8885QAS range - right-front stove top burner not working
burner
30 replies to this topic
#21 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 25 January 2012 - 10:16 PM
Oh i understand now. Where do i put the black lead ? I assume 1 and 3 ?
#22 Budget Appliance Repair
  • 4,001 posts
Posted 26 January 2012 - 08:44 AM
L1 = #2 (common to both ribbon elements)
L2 = #1 & #3 (I believe #1 is the outer ring which isn't working and #3 is the inner ring that is working)
Put one meter lead on #2 and the other is placed on #1 or #3 and you should get a reading of 240 volts if the switch is working correctly and set to the correct position.
If either #1 or #3 doesn't give you a volt reading of 240 then the switch is bad or you don't have it set to the correct position for both ribbons to be on.
If you do get a reading of 240 volts from both #1 and #3 then for sure the element is bad.
Edited by Budget Appliance Repair, 26 January 2012 - 08:49 AM.
William Burk (Willie)
Eureka, CA 95501
#23 RussTech
RussTech
    Kohai
  • 302 posts
  • Flavorite Brew:Heineken
Posted 26 January 2012 - 03:31 PM
Reading this thread almost made my head explode.
Somebody needs to buy these guys some beer!
#24 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 26 January 2012 - 08:02 PM
oh I am going to buy beers . I do it every time this site has helped me .... I would even design them a new site if they wanted one lol
Why explode ? I just did not understand why I could not do to ground. LOL Okay I am slow if he said measure 1 and 3 I would been fine.
#25 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 01 February 2012 - 09:10 AM
I got the 240v on the pins and i have installed the new burner. It still does not lite up either. I am not sure what is going on. I will give you ohm reading once it cools down. The inside rings light up. Just curious is there a model that does not light up the outer rings.
Edited by mmoore5553, 01 February 2012 - 09:13 AM.
#26 RegUS_PatOff
  • 30,275 posts
Posted 01 February 2012 - 09:43 AM
... I got the 240v on the pins
between which combination of Pins ?
#27 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 01 February 2012 - 11:09 AM
Okay i figured it out. It was me this time . I turned off the dual burner part to test the old part. I flipped it back on and it works. Thanks again everyone. I am putting up beer money.
#28 Samurai Appliance Repair Man
  • 24,334 posts
Posted 01 February 2012 - 11:14 AM
That's alright, amigo-- it was a fun romp and we got to see some purdy pitchers of the elements all aglow and atwitter. And we all learned a thing or two. :thumbsup:
#29 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 01 February 2012 - 03:16 PM
Curious i was trying to set the clock on the stove and now it says SAB ? on the digital display and shutting off power via the breaker and leaving it off did not fix it. I know i held the clock button in.
#30 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 01 February 2012 - 03:28 PM
Okay i fixed it by just holding the clock button in again.
#31 RegUS_PatOff
  • 30,275 posts
Posted 01 February 2012 - 06:12 PM
SAB = Sabath ..
Ovens usualy have that option so that you can't cook on that religious day
