Maytag Gas Stove MGR5720ADH Burner Ignitor Issues
Ignitor Arc Spark and Blows
3 replies to this topic
#1 55Ray
55Ray
  • 1 posts
  • Flavorite Brew:Sweetwater 420 and most IPA's
Posted 23 January 2012 - 09:49 PM
My control panel went out on the stove. Purchased a new one and installed it. When I powered up the stove, the broiler ignitor began to glow right away, then arced and blew burning the wire in half. I thought the wire may have had a bare spot in the sheath so I purchased a new ignitor and replaced it. Powered up and got the same results ... blew the new ignitor after a few seconds. I don't see any obvious frayed wires or anything that looks out of order. I don't want to blow the new control panel. Can anyone help me troubleshoot?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 24 January 2012 - 01:18 AM
Has this Range been working OK up till now at this location ?
There's no way the Ignitor (or wiring) can instantly burn-out, unless this Gas Range is wired for 240v instead of 120v.
    Shōgun
  • Master Samurai Tech
  • 30,720 posts
Posted 24 January 2012 - 04:30 AM
I gotta see this-- post some photos!
#4 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 24 January 2012 - 06:30 AM
Check your control board for mis-wiring. You may have put a hot(L-1) wire on a neutral terminal.
