plwcdi
LG Wm2277HW Washer won't turn on!
8 posts in this topic
Hi guys,
From what I can see You guys must be experts on Lg Washers now with all the problems they have. Mine is a 2003 model LG Wm2277HW. I sure do appreciate any help anyone could give to repair this unit. So we were doing a load of laudry, mid cycle when the unit tripped the breaker. I unplugged the unit,resrt breaker wait 30 min then plugged it back in. Washer would not turn on. Some history... Every few loads the code LE would come on and I would unplug wait 30 min. plug back in and it was fine for a few loads. What I have done so far; I saw a video from repair clinic on how to take unit apart. Outlet has 120v. Then checked to see if I had power in unit where cord meets unit. Yes there is power.(Unplugged unit). I opened PMB and looked for any burned spots, none. At this point I dont know what to do. Cant any one help?
Plwcdi
<<<we were doing a load of laudry, mid cycle when the unit tripped the breaker>>>
House/Home Fusebox Breaker or Wall Outlet GFCI Breaker?
<<<I unplugged the unit,resrt breaker wait 30 min then plugged it back in. Washer would not turn on>>>
Verify that the outlet has 120 volts AC by either plugging something else in that outlet or using a TEST METER.
If the wall outlet has 120 volts---verify that the NOISE SUPPRESSION FILTER has 120 volts coming from the **pink** connector (on the NSF---not the pink plug that goes into the NSF).
If 120 volts is verified at the NSF---replace the MAIN BOARD.
<<<Every few loads the code LE would come on and I would unplug wait 30 min. plug back in and it was fine for a few loads.>>>
Triggered by incorrect (non-HE) type of laundry detergent or too much of the correct (HE/High Efficiency) detergent.
With LG WM2277 washers---ALWAYS---order parts by providing both the MODEL & SERIAL NUMBERS---to ensure getting the *correct* replacement parts.
Edited by john63
2 people like this
Thank you John for your reply! I'll check it tonight.
OK, I have 120 volts verified at the NSF-- I guess i need to replace the MAIN BOARD.
Just one more question-- I know the Model number, Were are the SERIAL NUMBERS? ---to ensure getting the *correct* replacement parts.
Is it the Capacitors which were out? any thoughts?
OK found: Model # Wm2277HW
Serial # 403KW-01184
Can you direct me to right part?
