DCS RGS-364GDSS-L range one burner sparking continuously
5 replies to this topic
#1 TheIslandTinker
TheIslandTinker
    Ikkō-ikki
  • Chief Appliantologist
  • 20 posts
  • Flavorite Brew:Cafe Cristina
Posted 26 January 2012 - 03:39 PM
DCS--does that stand for Dammned Cantankerous Stove?
The owner called complaining that when ANY of the 4 burners was used, there was a constant sparking. After reading this very helpful post:
http://appliantology...0burner%20spark
I ordered and installed a replacement spark module. Partial joy--now three burners work normally and only one has the constant sparking. I have disassembled and cleaned that burner at least three times. Still tick tick tick. Does anyone have any other suggestions?
Thanks oh wise ones!
Tink
:tinkerbell:
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 26 January 2012 - 03:41 PM
.. I have disassembled and cleaned that burner at least three times.
have you (carefully) cleaned that Ignitor ?
#3 TheIslandTinker
TheIslandTinker
    Ikkō-ikki
  • 20 posts
Posted 26 January 2012 - 03:56 PM
I swiped it with steel wool and inspected the ceramic for cracks. Can you suggest a better cleaning method? Thanks Reg!
#4 RegUS_PatOff
  • 33,588 posts
Posted 26 January 2012 - 04:54 PM
try swaping that output wire with another, only at the output connection of the Spark Module.
#5 TheIslandTinker
TheIslandTinker
    Ikkō-ikki
  • 20 posts
Posted 27 January 2012 - 01:43 PM
OK, I will certainly try that. I assume that what I would be looking for is if the sparking problem moves to the other burner, there is something wrong with the spark module?
I could see the arc moving across from the ignitor to the burner. It passes right thru the flame, and connects to the burner ring. I don't understand why the flame is not cancelling the spark.
Unfortunately I will not be able to revisit the customer for a week--I am only servicing that area once a week--so I would really like to have a plan for what to look for. The customer and I are getting a bit tired of each other! Any more hints you can think of would be much appreciated.
Tink
#6 RegUS_PatOff
  • 33,588 posts
Posted 27 January 2012 - 02:46 PM
yes, the problem should move... unless that Output High Voltage Wire is defective.
The Spark Module should "sense" the difference in the electrical Spark (feedback) when there is a Flame
(unless that replacement Spark Module is defective)
