Sign in to follow this
Followers 0
mehoss
Kenmore(Whirlpool) French Door Bottom Freezer 596.75533400 No Water Flow
6 posts in this topic
Hi folks,
I have hit a very strange problem. I think this is the second one actually, the first incident the customer (and I) gave up on. Now I have hit it again. Here is the issue. No water to the inside dispenser or ice maker. Must be the filter or valve, right?? Well nope, I have the water filter bypass installed and was about to replace the water valve when I thought I would remove everything and simply try water from the supply up to the filter (bypassed) and out of the filter into a bucket. I fully expected water to flow. Nope, no water. The only way I could get water to flow for about 10 seconds was to turn the water valve on very minimal (low pressure) and it flowed for about 10 seconds weakly then shut off. There are no valves or anything in the water "circuit" just the line headed up to the water filter with a bypass on it. I can even blow with my mouth into the filter assy and air comes out the other end, but when water is run, it shuts off.
Also when everything is hooked up, If I loosen (and then tighten) the filter bypass I hear a sudden rush of water and it will dispense for a few seconds, then shut down.
I know that this sounds as if I need to replace the entire water filter assy, I find it hard to believe.
anyone seen this before?
Thanks in advance!
-Henry
I'm going to replace the water filter head unit in next few days, I'll update my post with the results.
You aren't, by chance, connecting it to a FloodSafe inlet line are you ?
.. FloodSafe inlet line are you ?
OR any "funny" Hoses ?
Are you using a "saddle clamp" water supply ?
Those Valves usually get clogged
It is not a saddle valve, it is a 1/4 turn valve. Hmm...flood-safe....i don't know. It IS acting like it is attempting to prevent water from flowing out of it.
I notice a strange brass fitting on the input to the filter down near the valve, is that a floodsafe device I wonder?
Before I replace the filter head unit, I will open just the valve and see if it pours unrestricted into a bowl for a few seconds. If so, I will replace the filter head unit. If not, the valve gots ta go! The fellow behind the appliance parts counter says he sells a lot of those head units, mentioned that as soon as customers replace the filter, they start having issues.
I promise to update this thread as soon as they let me back into their home.
Edited by mehoss
SOLVED!
OK, well never got back to THIS one, but many similar repairs later, I can honestly say that the HEAD UNITS suck big time with these new water filter models. Seems whirlpool and GE and Korean units all have this issue. I performed an autopsy on one of the head units and found that the rubber seals that allow you to remove the filter and keep the water from spilling out were expanded. This may be from the wonderful chemicals added to the drinking water around here. I now tell my customers that I will bypass the Head unit and install a filter on the back of the fridge. It's a great solution because the replacement filters are about $12 and not $40 each.
Followers 0
