Kenmore 106.53606202 icemaker will not do force harvest
1 reply to this topic
#1 kevrobin45
kevrobin45
  • 1 posts
Posted 28 January 2012 - 02:17 PM
I jumped points T & H and it will not harvest. History on problem, walked in and found water on floor, looked like it came from stuck ice in dispenser, cleaned that up and opened freezer and found ice on bottom of freezer. Looks like it over filled but now it will not make ice. Could it be the ice-maker or the emitter/receiver boards?
#2 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 28 January 2012 - 03:55 PM
there's a little more to cycling the icemaker
on units with the emitter/ receiver boards.
make sure the flapper is closed over the
emitter board, jump T & H, shut the door,
unplug the frige, wait 15 seconds, plug
frige back in. Ice maker should start to cycle in
about 5 seconds.
are the tines that rotate to eject the ice
in the 2' Oclock position if your facing the front
of the icemaker as pictured below? if not and they are stuck in
3-6 o'clock position and theres no ice in the mold then the module
is bad.
Emitter / receiver diagnostics
4389114.pdf
(2 pages)
Edited by RegUS_PatOff, 28 January 2012 - 04:38 PM.
www.eliteapplianceservice.org
