  • Announcements
HillEnt
Maytag MDE 9700 AYW dryer meltdown
2 posts in this topic
Greetings folks-
Have a Maytag Neptune MDE 9700 AYW electric dryer with a symptom of "spins but no heat". Upon disassembly discovered melted connection at motor. Motor tests and appears good. Apparently high resistance at connection is cause. Need: Replacement connector or sub harness plus any comments and advice.
Thanks for any and all input-
HillEnt
You can't get the connector but, you can carfully remove the burned wire
from the connector and crimp a new terminal on (of appropriate size) and
trim the plastic main connector enough that you can plug the repaired wire
directly to the motor.
