Lg wm2277hw Washer
Door will not stay shut
2 replies to this topic
#1 whonneb
whonneb
  • 2 posts
Posted 29 January 2012 - 03:59 PM
I have a wm2277hw washer and the door will not stay shut, thus the washer will not work. After reading a couple of forums, I replaced the door latch 6601er1004c and the problem still exist. Is there something else that could be the problem or do I have a bad part?
#2 whonneb
whonneb
  • 2 posts
Posted 29 January 2012 - 04:10 PM
I will appeciate any help
#3 john63
john63
    Dean of LG Appliantology
  • 2,218 posts
Posted 29 January 2012 - 04:14 PM
Replace the DOOR HINGE ASSY
http://www.repaircli...ER2002A/1267595
In many cases---the stainless steel screws to the hinge are *frozen* by the corroded aluminum.
Use a propane torch to heat each screw for 30 seconds---then remove the screw.
NOTE: Heat the screws on the hinge side---not from the FRONT COVER/PANEL.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
How to fix an LG washer with a door that will not stay closed (which keeps the washer from running)
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 30 January 2012 - 06:43 PM
In many cases---the stainless steel screws to the hinge are *frozen* by the corroded...
Read Full Entry →
