Kenmore 110.46462500 washer noise during spin - bearing ?
1 reply to this topic
#1 CMcD
CMcD
  • 2 posts
Posted 30 January 2012 - 08:47 AM
My Kenmore 110.46462500 washer just started making a load noise during the spin cycle. It does spin and take the water out of the clothes, but it makes a loud noise, kind of like an amplified version of what a vacuum cleaner makes when the brush-head is spinning against a hardwood floor. But very loud!
I've read that it is most likely the (very expensive to replace) bearing. How can I confirm?
When the machine is off, I noticed that the drum seems to have a lot of play/movement when I spin it. It seems to "slosh" around, rather than be firm. Is that normal, or a symptom of some sort?
Thanks!
Chris
#2 Skiter29
Skiter29
    Kohai
  • Appliantologist
  • 360 posts
Posted 30 January 2012 - 06:25 PM
take the back off and see if its been leaking from the bearing area then take belt off and spin it buy hand if its sounds bad its the bearing
