Samsung, WF448AAP, Washer, Leaking inside
5 replies to this topic
#1 pyperdaddy
pyperdaddy
  • 3 posts
  • Flavorite Brew:Miller Genuine Draft
Posted 30 January 2012 - 02:06 PM
Newb here, would like to request a repair manual for a Samsung WF448AAP to track down where the leak is coming from.
Thanks in advance
#2 RegUS_PatOff
  • 30,266 posts
Posted 30 January 2012 - 02:39 PM
When using non-HE detergents,
or using too much detergent for the water hardness and soil level of the clothing,
over sudsing will occur.
When this happens there will be leaks out of the detergent drawer and door.
Please advise consumer of proper detergent usage.
for service manuals and other perks
Become an Apprentice Appliantologist
#3 pyperdaddy
pyperdaddy
  • 3 posts
Posted 30 January 2012 - 07:22 PM
I am now an apprentice, Tide for High Efficiency is the detergent that I use. I was reading on another forum about the pump hose might be loose. I just need to know how to get to it.
#4 RegUS_PatOff
  • 30,266 posts
Posted 30 January 2012 - 07:38 PM
http://appliantology...service-manual/
#5 pyperdaddy
pyperdaddy
  • 3 posts
Posted 30 January 2012 - 08:21 PM
RegUs you are the best...
Thanks Again
#6 john63
john63
  • 1,411 posts
Posted 30 January 2012 - 08:34 PM
Samsung WF448 washers were known for having a *split/burst* hose---for the SILVERCARE option.
Remove the TOP COVER of the washer
Run a cycle with SilverCare---or---examine the hose which leads from the cluster of water valves (COLD WATER VALVE ASSY) to the SILVERCARE MODULE (located on the center-frame-support).
If a leak occurs from this hose---replace the HOSE.
Always unplug the washer before touching any innards---which may be wet and present a potential shock hazard.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
