Kenmore Elite Microwave 665.63799305 F7 error code
#1
Posted 30 January 2012 - 04:50 PM
#2
Posted 30 January 2012 - 05:02 PM
RUN AWAY !
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Check for reversed plug connection on controls or loose wiring.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
#3
Posted 30 January 2012 - 06:10 PM
#4
Posted 30 January 2012 - 06:16 PM
#5
Posted 08 February 2012 - 08:48 AM
#6
Posted 08 February 2012 - 09:00 AM
#7
Posted 08 February 2012 - 09:27 AM
