RTEXASS13
BOSCH wfmc1001uc07 washer wont spin
7 posts in this topic
Ok let me give you the lo down with this washer. about a month ago i serviced this washer. i put it in the spin mode and the washer would pump water out and the start to spin, it would spin for about 2 seconds and stop. so i checked power to motor from motor control board and there was no power. when the washer try's to spin i hear a relay inside the control click then shut off. so i replace motor control board and it worked for a month. now its doing the same thing. so i thought faulty board again, ordered another one and installed and still will not fix it. sends power for to motor and shuts power to motor in 2 seconds. still hear clicking in motor control board. motor moves freely . power get to the board but will not send power out. any suggestions would be appreciated .
Put the washer into diagnostic mode and check the stored error codes. Also, run the test program to see if the washer spins normally in test mode. Report.
If the Motor has an overload, it could be opening (maybe due to bad motor, or drag from tub ?).
Looks like that Motor has been Disco'd !
Ouch it subs over to this guy:
660487 MOTOR
DEC 2011 IF USING THIS MOTOR TO REPLACE 436478, IN SOME CASES MOTOR AND WASHER CONTROL MAY NEED TO BE REPLACED. MODEL # INFO AVAILABLE W/ PURCHASING
Part number: 660487
Part number: 660487
Edited by RussTech
thanks for the help guys. took the motor off and found one of the motor brushes was worn down to the nub. i could not get new brushes from my supply house, they said I had to buy new motor (190.00) so i took some brushes off a frigidaire motor. had to sand them down but it worked. washer is working fine. thanks again for all the help
Good find and domo for posting it! :dude:
