GSS22WGPDWW Water pressure
7 replies to this topic
#1 barryblanken
barryblanken
  • 3 posts
  • Flavorite Brew:Bud Light Lime
Posted 01 February 2012 - 07:41 AM
I just moved into a new house and the fridge is not dispensing water with any vigor. All I get is a slow stream or a drip. I did some research and found the solution to install the heater to make sure the line doesn't freeze. So I ordered one online only to go home and look and see it already installed. When I put my ear up to the fridge and listen for the click, i do hear it, and I do hear a slight hum. Water does come out, however it's slow and sometimes just stops. I also put a hair dryer to it, for 15 minutes with no change.
Is there a water pump that provides pressure so water comes out at a fast rate?
The fridge makes ice and dispenses it just fine. There doesn't see to be a problem there. It's just with the water pressure.
Any advice?
Thank you,
Barry
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 February 2012 - 08:31 AM
normally, it would seem to be a clogged Water Filter,
but on that model, the the dispensed water, and the IceMaker water is filtered.
There is no water "pump", just a Water Valve that lets the House water pressure flow.
It may be a bad Water Valve, or a clogged inlet screen on the Valve.
#3 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
  • Flavorite Brew:Killians Red
Posted 01 February 2012 - 12:11 PM
The icemaker on this one, if it has the green LED, is "smart" enuff to compensate for low pressure...
Install the bypass plug or a new filter and see if it s better.
#4 RegUS_PatOff
  • 33,588 posts
Posted 01 February 2012 - 12:21 PM
... Install the bypass plug or a new filter and see if it s better.
http://www.repaircli...R=154&N=1038637
Water-Filter-Bypass-Plug-WR02X11705--008
http://www.repaircli...R=154&N=1156599
#5 barryblanken
barryblanken
  • 3 posts
Posted 01 February 2012 - 12:51 PM
They said if you took the filter off, the water would still run. I took the filter off and still had the same results.
Whats the bypass filter do? I already have a new filter on order.
How could I get to the clogged screen? Where is the valve? Where would that be? I'll be sure to check them all tonight
#6 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
Posted 01 February 2012 - 04:23 PM
not true..
the bypass does what the name implies...allows water to flow thru the filter base without a filter in place.
the screen is in the watervalve...may not be servicable.
have a helper press the water switch while checking the flow right out of the valve... disconnect the larger of the two lines from the valve and observe ...
#7 barryblanken
barryblanken
  • 3 posts
Posted 06 February 2012 - 10:17 AM
Thank you for all your answers. The problem was the water filter. I put in a new filter and water flowed normally.
#8 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
Posted 06 February 2012 - 05:15 PM
Rawk on!
