Bosch she44c05uc Dishwasher not finishing cycle
13 replies to this topic
#1 Jonathan Then
Jonathan Then
    Ikkō-ikki
  • 24 posts
Posted 01 February 2012 - 05:48 PM
Hello! i have a bosch she44c05uc that is not finishing its cycle usually with 2-3 minutes remaining, it will stay in cycle until i hit cancel. i did a bit of research and from what i can gather its the circuit board one of the resistors or something is fried? (correct if wrong) I'd like to replace whatever part it is that is causing this problem as the dishwasher is fairly new. I think i need this but really love you guys and trust your judgement.
http://www.repaircli.../676960/1557799
Main Control Board
Item #1557799 (OEM Part)
$118.50
Control unit
Manufacturer Number 676960
can anyone supply info on whether
1. i am right about this part needing repair or replacing
2. the procedure for repairing/diagnosing and how to take apart the front of the dishwasher.
also do i need to remove this dishwasher from the power source first? (probably a silly question)
thanks guys. love this site.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 February 2012 - 06:27 PM
... do i need to remove this dishwasher from the power source first? (probably a silly question)
:woot:
It may be a bad solder connection on the Heater Relay Pins on the Controller Board.
#3 Jonathan Then
Jonathan Then
    Ikkō-ikki
  • 24 posts
Posted 01 February 2012 - 07:19 PM
would you recommend replacing the control board, or attempting to repair the sodder?
#4 RegUS_PatOff
  • 33,588 posts
Posted 01 February 2012 - 07:23 PM
depends if you (or someone) can solder, etc ..
#5 Jonathan Then
Jonathan Then
    Ikkō-ikki
  • 24 posts
Posted 25 May 2012 - 10:09 AM
ok got the dishwasher apart, but can't get to the control panel! its surrounded in plastic! any ideas?
#6 Jonathan Then
Jonathan Then
    Ikkō-ikki
  • 24 posts
Posted 25 May 2012 - 03:40 PM
ok, i went ahead and ordered the part, I couldn't visually confirm that the control panel is the problem because I couldn't remove the housing... did I make a good move or was this a bonehead idea?
#7 kdog
    RoughShod
  • 7,466 posts
Posted 25 May 2012 - 07:54 PM
Replacing the control is th best option - the plastic casing does come apart if you manipulate all of the little locks on it
see here: http://appliantology...e/276-img-0491/
#8 Jonathan Then
Jonathan Then
    Ikkō-ikki
  • 24 posts
Posted 25 May 2012 - 09:44 PM
thanks! new part should arrive wednesday, I will update once I get it installed and run the dishwasher to see if that was the problem, then take a hammer to the plastic covering on the old one to see if it was the board.
#9 kdog
    RoughShod
  • 7,466 posts
Posted 26 May 2012 - 12:01 AM
Don't smash it, release all of the clips around the middle of the housing (visible here) - examine the relay pin solders (which are likely burnt) - repair it at your liesure and keep on hand to swap if and when that reoccurs.
The clips are a bit of a chore to pry open all at once - work at it carefully with a small screwdriver.
#10 Jonathan Then
Jonathan Then
    Ikkō-ikki
  • 24 posts
Posted 26 May 2012 - 07:44 AM
fair enough! i did try for hours yesterday to open that thing, I can get a few of the clips, but I have no idea where the other ones were, your pictures are fair at best :woot: is there a way to get me a picture of the clips? i'd be greatly appreciative of it! otherwise, i will give it another go when i have a glass of scotch and 5 hours to kill :rocker: :rocker:
#11 Jonathan Then
Jonathan Then
    Ikkō-ikki
  • 24 posts
Posted 30 May 2012 - 04:55 PM
Great Success!! it worked!! Thank you Guru's for all your help! when i get some time im going to sit down with a glass of scotch and pry that control panel housing apart!
576761_10150858851903017_500918016_98093545180_10150858852258017_500918016_98093
#12 Jonathan Then
Jonathan Then
    Ikkō-ikki
  • 24 posts
Posted 31 May 2012 - 01:55 PM
I owe you guys some beers when you come to NYC. seriously.
i took your advice, sat down with some dental picks, some micro-screwdrivers and a glass of jamaican rum on the rocks and went to work. managed to get that sucker open! problem diagnosed and confirmed!
This image is from the top side, where the burnt pin is.
    Shōgun
  • Master Samurai Tech
  • 30,367 posts
Posted 31 May 2012 - 03:49 PM
The pics with the rum were worth the upgrade to Merit Apprentice Appliantologist, together with all the rights and privileges thereof. Kanpai! :samurai:
#14 kdog
    RoughShod
  • 7,466 posts
Posted 31 May 2012 - 11:53 PM
Excellent follow up and Pictures! especially the one with the rum in it - Good Job on the repair and extra good when it occurs again
0 members, 1 guests, 0 anonymous users
