LG Tromm wm1814cw squeals on startup
1 reply to this topic
#1 arfrieman
arfrieman
  • 1 posts
  • Flavorite Brew:Jack
Posted 05 February 2012 - 01:37 PM
My LG Tromm wm1814cw squeals on startup. The noise stops after about 2 minutes. Can anyone help?
#2 john63
john63
    Dean of LG Appliantology
  • 2,218 posts
Posted 05 February 2012 - 05:31 PM
Does the squeal occur when...
The WATER VALVE(S) are on? (possible failed WATER VALVE)
The TUB begins to tumble? (possible early-stage rear BEARING failure or the DOOR GASKET is rubbing the stainless steel tub
lip)
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
