Hotpoint Drier model#DLB3600SBLWH
intermittent heating
7 replies to this topic
#1 Pete Laframboise
Pete Laframboise
  • 5 posts
Posted 05 February 2012 - 06:31 PM
drier sometimes wont heat up and sometimes it will.. could it be a sensor? i took the drier apart and checked for lint buildup and it was clean. i saw 3 of them on the heating element casing.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 05 February 2012 - 06:58 PM
check your Venting System
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
 $ 4.99 sometimes on sale for $ 2.99
#3 Pete Laframboise
Pete Laframboise
  • 5 posts
Posted 05 February 2012 - 07:16 PM
I did that and its all fine. the heating element sometimes works and sometimes doesnt. right now its working. i can only come to the conclusion temp selector switch, timer or a sensor. im not a tech so i cant be 100%
i didnt check the temp. ill have to check it in the morning. what should the temp be at .?
#4 Pete Laframboise
Pete Laframboise
  • 5 posts
Posted 05 February 2012 - 07:31 PM
oh you told me sorry.
#5 RegUS_PatOff
  • 33,588 posts
Posted 05 February 2012 - 07:35 PM
here's some stories about the Timer in that model:
Inconsistant heat... had heat for one cycle and none the next or heat would stop half way through dry cycle
Removed the screws from the back of the control panel. Unplugged the old timer assembly and the timer knob. Plugged in the new timer assembly and put the timer knob on. Put the back panel back on and screwed it back on. Very simple. The dryer now works like new. It has instant heat right away and everytime it used. The selector knob was also installed by just slidding it on. I absolutely love this website...it's save me so much money in having to pay someone else to fix it. smile.png
Intermittent heat, abirtrary run time
After ensuring all 5 temp sensors were not open, replaced the timer assy by removing the back of the control section. ( 5 screws ) . removed both wire connectors and 1 screw. removed the old timer assy and knob. put old knob on new timer, installed into slots, installed screw and replaced wire connectors. replaced back panel and vent hose, applied power. Works like new
No heat, intermittent heat
Removed timer and put new one in. Perfect! Also replaced belt and it went in perfectly. Vacuumed out the interior too.
No heat on some cycles, wouldn't run a long time, clothes wern;t dry
Pulled the plug from the wall outlet. Removed back on control panel. Removed switch, installed new switch. Very easy. Also had to replace the knob, as it was cracked where it slides over the stem of the timer
No heat
Long eventful troubleshooting. No success. Read your troubleshooting guide. Showed either high temp. sensor or timer. One person commented go straight to timer. So I did. 2 minuite repair, back in service. Thanks
http://www.repaircli...sp?R=154&N=1257
Mechanical-Timer-or-Clock-WE4X795-007911
#6 Pete Laframboise
Pete Laframboise
  • 5 posts
Posted 05 February 2012 - 08:40 PM
so it could be the timer? best guess?
#7 RegUS_PatOff
  • 33,588 posts
Posted 05 February 2012 - 10:11 PM
intermittents are hard to diagnose
just a guess...
http://www.repaircli...r/Return-Policy
#8 Pete Laframboise
Pete Laframboise
  • 5 posts
Posted 06 February 2012 - 05:36 PM
intermittents are hard to diagnose just a guess... http://www.repaircli...r/Return-Policy
i dont beleive it is the timer. its just a simple clock with contacts internaly i cleaned the contacts and its no change in how the drier acts. oh well worth a shot to try that
