Sign in to follow this
Followers 0
heyjuliebean
Front loader leaking from door.. Samsung WF218ANW/x99
5 posts in this topic
I noticed water leaking out the door toward the bottom. When I open the door I can see moisture as high as the screws near the hinge area, so I think it is coming from that area . I cleaned the entire grey rubber thingy and examined it with a flashlight. I cannot see any cracks or holes. Is it possible it is coming from something else, or do you think the grey thing needs replaced. Also if it is that, is it very hard to replace??
thanks
<<<When I open the door I can see moisture as high as the screws near the hinge area, so I think it is coming from that area>>>
Possible leaking from the DETERGENT DISPENSER area.
Remove the DRAWER from the Dispenser---examine the HOUSING for debris (such as a cap from a bleach bottle). Remove any obstruction found.
Can also be *suds*.
It's important to use the correct type & amount of detergent.
2 people like this
I found that it is leaking from the drawer and migrating down, I will clean it and see how it goes...
1 person likes this
I cleaned it and it is still leaking. I ran it with the drawer out, and it looks like the water is not exiting the drain fast enough. How can I clean that drain out??
thanks
Unplug washer.
Remove 2 silver-colored screws at the rear of the TOP COVER.
Grasp both sides of the Top Cover and slide rearward about an inch or two. Lift up cover.
Locate the Dispenser Assy Hose at the front of the tub.
Disconnect hose and remove debris.
Re-install & test washer.
2 people like this
Followers 0
