Under counter Kitchenaid ice machine KUIS18NNTB2 began making a high pitched humming noise
Kitchenaid ice machine screech
6 replies to this topic
#1 drstroud
drstroud
  • 3 posts
Posted 06 February 2012 - 03:50 PM
My ice machine started making a high pitched noise. There was a layer of ice in the reservoir. I ran it through a clean cycle and cleaned the coils (which were quite dusty). Than I restarted it. Approximately 24 hrs later it did the same thing again.
Prior to the first episode, I had emptied the storage bin to fill a cooler.
Any idea what is causing ice to form in the reservoir? I feel like this is the main symptom of the root problem leading to the screech/hum.
#2 jumptrout
jumptrout
  • 1,134 posts
  • Flavorite Brew:Coors Light
Posted 06 February 2012 - 04:30 PM
Compressor
Condenser fan motor
water pump
These are the 3 things on this machine that could make a sound as you described.
Since none of us are there you will have to determine which is going bad and making the sound.
Probably not the compressor.
#3 drstroud
drstroud
  • 3 posts
Posted 06 February 2012 - 04:45 PM
If I get this ice out of the reservoir and turn the machine back on, it operates fine...making ice as if everything is fine. I am just wondering what causes the ice to get below freezing in the reservoir.
Meant to say "water to get below freezing in the reservoir."
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 06 February 2012 - 05:08 PM
Appears to me your circ pump is failing...next time it makes the noise,check to see that water is cascading over the freeze plate.
If not, access the plug to the circulation pump and disconnect it. Does the noise stop? Then there you are.
I have only seen the water reservior freeze on units who's. Circ pump has failed...
  • 24,258 posts
Posted 06 February 2012 - 05:27 PM
Circulation pump part link ==> Circulation Pump
#6 drstroud
drstroud
  • 3 posts
Posted 10 February 2012 - 09:21 AM
I was able to buy a pump and repaired the machine. Thanks for the help! Now it seems to be making too much ice...have I damaged another part? My research is telling me the thermistor may need replacing. What's going to go bad next?!
#7 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
Posted 10 February 2012 - 10:09 AM
Too much? Is the ice piling up on the door and falling out when you open it?
Yea, verily...may have a bin thermistor problem..
Usually see those fail open or shorted...take a resistance reading and do tell.
Also tagged with one or more of these keywords: Kitchenaid, ice machine, screech
