Maytag MSD27567GES refrigerator - Replacing ADC, runs continuously meanwhile
7 replies to this topic
#1 jdarago
jdarago
  • 3 posts
Posted 07 February 2012 - 03:55 PM
I am replacing the Adaptive Defrost Control. I ordered the part with the LED, put its going to take a couple of days to get here. Meanwhile, the fridge runs continuously. Will this fry anything? Should I pull the plug every so often?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 February 2012 - 05:17 PM
... the fridge runs continuously.
why is the Fridge running continuously ?
What was the reason you wanted to replace the ADC ?
#3 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 07 February 2012 - 06:01 PM
Hopefully have a defrost problem!
#4 kdog
    RoughShod
  • 7,466 posts
Posted 07 February 2012 - 06:15 PM
Is the evaporator coil all frosted up ? if so, you gonna need to defrost that even if the ADC is tha cause to restore proper function. "ASSUMING" your model # is MSD2756GES
Ten Commandments for Reading Appliance Model Numbers :)
#5 jdarago
jdarago
  • 3 posts
Posted 07 February 2012 - 07:21 PM
Sorry, typing too fast. It is an MSD27567GES. It has all the signs of the ADC failure. This happened many years ago and I replaced it with an OEM 61005988. I got a warm fridge, frost/ice on the coils.
How about letting it run continuously until the part arrives? Do I or don't I?
#6 jumptrout
jumptrout
  • 1,380 posts
  • Flavorite Brew:Coors Light
Posted 07 February 2012 - 09:00 PM
It would be best to turn it off.
It has to defrost anyway.
I hope it is the ADC and not the defrost terminator.
Edited by jumptrout, 07 February 2012 - 09:00 PM.
#7 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 07 February 2012 - 09:04 PM
Defrost and check defrost tstat and that the evaporator fan is working as well!!!
#8 jdarago
jdarago
  • 3 posts
Posted 17 February 2012 - 07:03 PM
Just wanted to close this out. Replace the ADC with the newer version and all is well.
