Maytag Dishwasher Model MDB7160AWB Red lights flashing
2 replies to this topic
#1 rickk
rickk
  • 3 posts
Posted 07 February 2012 - 11:03 PM
My dishwasher has 6 lights flashing on the desplay and none of the buttons work. I think that the touch pad might be bad but I don't know how to test it. Any help?
#2 certified tech group 51
  • 2,712 posts
Posted 07 February 2012 - 11:55 PM
Have you found the tech sheet down behind the toe plate/ lower panel??? Some Maytag d/w's have good tech sheets that will give you the key pad/button locations on the ribbon connector... BUT, looking at your model number , you will need the control board with the very small pittance of $$$ 237.70............. with a core charge of only $ 35.00 clams..............Have you tried disconnecting the power for a few minutes and then powering it back up ???
#3 rickk
rickk
  • 3 posts
Posted 08 February 2012 - 09:58 PM
I did find the tech sheet and it did not give the button locations but I think with a little effort I can figure that out. If you are right and the control board is bad
$$$237.70 is at least half the price of a new machine. Forget that it has no real time on it I don't think that it is worth putting money into. Anyone want a used dishwasher cheep? Thanks for your input.
