Kenmore 911 61778790 Range: stove burner Indicator light stays on, how to find which switch is bad?
9 replies to this topic
#1 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 08 February 2012 - 11:25 AM
Model 911 61778790 Indicator light stays on after all burners are cool! What's the fastest way to determine which infinite switch is bad???
#2 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 08 February 2012 - 11:36 AM
Theres only one indicator light that all four burners share, and I always begin with the front two burners because they normally see the most use!!!
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 08 February 2012 - 11:52 AM
you could try carefully disconnecting the P (pilot) Terminal of each Burner Switch
(one at a time)
#4 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 08 February 2012 - 12:19 PM
Thanks for feedback! Couldn't remember how I tackled these problems and feeling sick just want to be done with today and feel heathy again!!!!
#5 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 08 February 2012 - 08:24 PM
Stupor-Bowl catching up with you ?
#6 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 08 February 2012 - 08:28 PM
I wish it was a brown bottle fiu and not just a nasty cold of some sort!!! UGH
#7 certified tech group 51
  • 2,712 posts
Posted 09 February 2012 - 12:50 AM
As RegUS recommends, Unplugging each one till the pilot light goes out,is about the only way to find the failed switch..You cannot do a voltage check, cuz voltage is at all of the 'P' terminals of the switches.................
#8 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 09 February 2012 - 07:18 AM
You can disconnect the switch wires and do a continuity check to P with the switch in the OFF position. Usually from L1.
#9 certified tech group 51
  • 2,712 posts
Posted 10 February 2012 - 12:06 AM
Jumptrout, no fun in doing that way..Imagine having the shakes from your most recent hangover :pint1: , trying to remove and reinstall the terminal, all the time it is energized :woot:........................ P.S. remove power, then disconnect switch wires. :rocker:
#10 jumptrout
jumptrout
  • 1,382 posts
Posted 10 February 2012 - 07:25 AM
That was in my post. I used invisible type. :dazzler:
