Frigidaire Gallery Series GLTF2940FS1 Front Load Washer won't operate
#1
Posted 08 February 2012 - 01:05 PM
The error code it gives me is E23.
By reading other similar post on this forum, I decided to check the pump filter for any clogs/debris. That turned out nothing, it had nothing but water in it. Checked the drain hose and it was clear. I have also ran the diagnostic test as detailed in the tech data sheet. Water flows into the machine, door will lock, and then unlock, When it gets to where (during the test) the machine should fill and tumble, then fill and spin, it does not do this, it also will not drain the water during the test.
We are trying to fix this ourselves, but aren't quite sure where exactly to start. Any help would be greatly appreciated.
#2
Posted 08 February 2012 - 02:08 PM
E23 Drain pump relay on control board failed. Replace control board.
You could verify by checking for 120v AC at the Drain Pump
http://www.repaircli...R=154&N=1472564
#3
Posted 08 February 2012 - 02:30 PM
#4
Posted 08 February 2012 - 08:09 PM
#5
Posted 08 February 2012 - 10:31 PM
#6
Posted 08 February 2012 - 10:57 PM
#7
Posted 11 February 2012 - 12:34 PM
#8
Posted 11 February 2012 - 06:38 PM
#9
Posted 11 February 2012 - 07:43 PM
#10
Posted 11 February 2012 - 09:38 PM
But what about that plug? Is that insignificant?
#11
Posted 12 February 2012 - 12:18 AM
So, we opened it back up, hubby says that the propeller has a catch to it about every 3/4 turn. While in there we checked again for more items, but it seems to be clear of everything but water now. He's wondering about that catch that it has to it. Should it be doing that?
#12
Posted 12 February 2012 - 12:38 AM
If your referring to when you spin impeller with finger yes! That is the magnet of the motor its normal! Use a cheater cord and plug pump into an outlet and see if it's spinning!
#13
Posted 12 February 2012 - 12:39 AM
#15
Posted 12 February 2012 - 12:46 AM
#16
Posted 12 February 2012 - 12:56 AM
#17
Posted 12 February 2012 - 01:05 AM
#18
Posted 12 February 2012 - 01:21 AM
#19
Posted 12 February 2012 - 02:18 AM
#20
Posted 12 February 2012 - 07:15 PM
Sounds like the pump is hosed. Not uncommon to see that in these dinky pumps after when the gookus makes it past Ye Olde Craptrap and into the impeller ==> Drain Pump and Motor
- kdog likes this
