Maytag dryer mde9700ayw drum support rollers
whirlpool drum support rollers
11 replies to this topic
#1 mdadian
mdadian
  • 18 posts
  • Flavorite Brew:Killians
Posted 08 February 2012 - 04:50 PM
I'm trying to replace just the rollers for this dryer. All I can find are the full assemblies for $30 - $40 each. Can I substitute the red rollers (10314173) (37001042) for the blues rollers? or is there a place I pick up the blue rollers for a reasonable price?
He is Risen!
#2 jumptrout
jumptrout
  • 1,126 posts
  • Flavorite Brew:Coors Light
Posted 08 February 2012 - 06:42 PM
These are black. Try them $8.80 each.
http://www.repaircli...37001042/966673
#3 mdadian
mdadian
  • 18 posts
Posted 08 February 2012 - 08:33 PM
Thank you Jumptrout for the suggestion. I notice that these are square across the edge, and the ones being replaced are beveled. Does this make a difference?
He is Risen!
#4 kdog
    RoughShod
  • 7,428 posts
Posted 08 February 2012 - 08:35 PM
They weren't originally, they have worn
#5 mdadian
mdadian
  • 18 posts
Posted 08 February 2012 - 10:00 PM
This is the full assembly of the blue roller support. http://click.linksyn...-ap4374843.aspx
What i'm hoping for is just the rollers themselves or a reasonable facsimilie. I've seen the red rollers
http://www.repaircli.../4392067/587637 and wondered if they would do, since they, too, are whirlpool products used on maytag dryers. any thoughts? Will the white ones you suggested fit the same track as the blue rollers above?
Edited by Samurai Appliance Repair Man, 09 February 2012 - 05:25 PM.
Appliantologized the part link. :)
He is Risen!
#6 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 08 February 2012 - 10:22 PM
If your not going to use the original replacement rollers then use whatever you want. It's your dryer. Your rollers are beveled, not squared. Make sure they fit the shafts also. I think you should buy the kit with rollers and belt but thats just my opinion.
#7 RegUS_PatOff
  • 30,201 posts
Posted 08 February 2012 - 10:48 PM
Maytag dryer MDE9700AYW made by Samsung
http://www.repaircli...R=154&N=2027851
#8 Budget Appliance Repair
  • 3,996 posts
Posted 09 February 2012 - 06:03 AM
That is a Samsung built for Maytag. The standard 349241T won't work, shaft diameter is different, (I tried it on the first one of these Samsung/Maytag's I worked on). Mdadian, those red hub rollers in that maintenance kit are just the heavy duty style but same size as a set of 349241T's, they won't fit on the Maytag/Samsung's shafts.
Don't know if the SpeedQueen style roller that Jumptrout suggested will work or not, (Jumptrout, have you used one of what you suggested in the field and know it will work?).
I believe the LG rollers with shafts that are a little cheaper may work for you but haven't verified that myself.
LG dryer rollers/shaft assm. 4581EL2002A
Part number: AP4437815
Comparing the two on RepairClinic it doesn't look like the LG one will work, shaft appears too short and would not have the front to back float that the Samsung has unless the front and back shafts are different.
Samsung/Maytag:
http://www.repaircli...Number=35001136
LG
http://www.repaircli...EL2002A/1266815
Edited by Budget Appliance Repair, 09 February 2012 - 06:15 AM.
William Burk (Willie)
Eureka, CA 95501
#9 jumptrout
jumptrout
  • 1,126 posts
Posted 09 February 2012 - 07:08 AM
No I have not used them.
I stopped my research for his rollers too soon.
The blue roller is the recommended roller.
Edited by jumptrout, 09 February 2012 - 07:10 AM.
#10 mdadian
mdadian
  • 18 posts
Posted 09 February 2012 - 09:54 AM
Guys, you are all aces! Thank you for all your help, it has made my decision much easier. Because of the risk of differing diameters of the shafts, I was reluctant to just pick one that looked right. I chose the Samsung 716782A, first for the price and, second because there seems to be no appreciable difference between it and the W10177428. I'll let you know how I made out. Thanks again one and all. :blinky:
He is Risen!
#11 mdadian
mdadian
  • 18 posts
Posted 05 March 2012 - 09:53 PM
Sorry I didin't get back here sooner. The Samsung 716782A wheels were a perfect fit. Not sure if the new posts would have fit correctly, but the new rollers slid perfectly onto the existing post. Excellent job everyone. See you all soon.
He is Risen!
#12 kdog
    RoughShod
  • 7,428 posts
Posted 05 March 2012 - 10:03 PM
Thanks fer letting us know - those machines were mage by Samsung so lotsa parts are interchangeable (just cheaper)
Also tagged with one or more of these keywords: whirlpool, drum, support, rollers
