Kenmore 110.26901692 washer agitates but does not spin in spin cycle
4 replies to this topic
#1 V&L Surveyor
V&L Surveyor
  • 1 posts
Posted 09 February 2012 - 11:39 AM
My Kenmore washer had the timer go bad (would not advance). I replaced the timer, which seems to work ok, but now, when it hits the spin cycle, it pumps out the water but it continues to agitate and won't spin.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 09 February 2012 - 11:56 AM
the Timer sends the correct Motor direction (forward) for Agitate
and (reverse) direction for Spin
Did you buy this Timer new ?
#3 RussTech
RussTech
    Kohai
  • Chief Appliantologist
  • 309 posts
  • Flavorite Brew:Heineken
Posted 09 February 2012 - 12:47 PM
Wouldn't it be impossible to pump out the water and agitate at the same time? Only on reverse, for spin, does the pump, pump out. If its trying to agitate, while in spin, and its draining. Theres something really wrong with that gearcase.
Part number: 3360629
Edited by RussTech, 09 February 2012 - 12:50 PM.
#4 RegUS_PatOff
  • 33,588 posts
Posted 09 February 2012 - 01:38 PM
... Wouldn't it be impossible to pump out the water and agitate at the same time?
... Only on reverse, for spin, does the pump, pump out.
:kopkrab: hmm... that's right
#5 phydeauxe64
phydeauxe64
    Sōhei
  • 104 posts
  • Flavorite Brew:"Double D" Turbo Coffee
Posted 17 February 2012 - 10:45 PM
try this... Fill it up on small load turn timer to spin cycle trigger the lid switch using small screwdriver and watch the agitator if it agitates while draining and spinning you need a new gearcase my friend..."see my friend Russtechs' earlier post for parts and video.
Edited by phydeauxe64, 17 February 2012 - 10:47 PM.
