Dacor ED30 Dishwasher vibration on drain, dishes not coming out clean and rack problems
#1
Posted 13 February 2012 - 12:15 AM
Humbly I beseech thee for wisdom.
Here are the problems:
1) Major vibrations when the washer drains and does not seem to clean the dishes thoroughly. I think these issues are related. I have removed the screens from the machine and cleaned everything in the "well" at the bottom of the unit but the problem seems to be getting worse as time goes by.
2) The top rack as plastic and nylon bearings that go between the stainless steel slides that it rides on and every single one of them has fallen out so the rack keeps falling off. Do I need to replace the slides or can new bearings be purchased and installed?
3) The bottom rack does not seem to fit quite right. Every dishwasher we get seems to have this problem. The wheels do not seem to ride correctly on the tracks that are part of the sides of the tub. The wheels seem to be to narrow and not ride on the track properly. Any ideas?
Thank you for your wisdom.
- Grasshopper
#2
Posted 13 February 2012 - 01:48 AM
Service Manual
Parts Catalog
Service Bulletin-Upper rack retro fit Instructions
Service Bulletin-Wont close, popping open, leaking
#3
Posted 13 February 2012 - 07:50 AM
- kdog likes this
#4
Posted 13 February 2012 - 01:54 PM
Edited by jeremyb, 13 February 2012 - 02:07 PM.
#5
Posted 12 April 2012 - 12:28 PM
#6
Posted 13 April 2012 - 02:03 AM
- kdog likes this
#7
Posted 14 April 2012 - 01:06 PM
#8
Posted 14 April 2012 - 02:12 PM
But don't get ahead of yourself on this-- start with a simple continuity check of the element and then graduate to voltage checks.
- kdog likes this
#9
Posted 05 May 2012 - 10:32 PM
Thanks.
#10
Posted 06 May 2012 - 05:13 AM
Sounds like the drain pump either has some gookus attached to one of the impeller vanes throwing it off balance or the bearings are shot. Try cleaning it out. If that doesn't work, then just replace the drain pump ==> http://www.repaircli...odelNumber=ED30
