FP GWL11 Code 37 error
No replies to this topic
#1 Lurking
Lurking
  • 1 posts
  • Flavorite Brew:Yuengling at the moment
Posted 14 February 2012 - 11:00 PM
Help! Have a code 37 error. Machine does fine thru wash cycles, and drains properly - as far as I can tell, but as soon as the wash cycle indicator goes out and it shifts to rinse mode, the pump kicks on for a few seconds then machine stops, and the dreaded beeping starts. Code 37 indicated by adding the lights -OOXOO XOX- (but the troubleshooting guide that came with the machine says it is a code 39). In diagnostic mode, pump works fine. Diverter valve functions properly, with normal pressure during both drain and recirculation modes. R&R'd hoses and pumps - found no obstructions. Not sure where to go from here....
