JennAir JGS8850BDS17 Range no spark on cooktop
JennAir Gas range
8 replies to this topic
#1 Brooke Falconer
Brooke Falconer
    Ikkō-ikki
  • Master Appliantologist
  • 40 posts
  • Flavorite Brew:Heif
Posted 15 February 2012 - 01:18 AM
Hello, i've got a JennAir Range, the Front Right Burner is not lighting, Switched Ignitor out and it is still not lighting, could anyone provide HOW to test to see if it is the Spark Module or the ignitor switch/wiring harness. On this particular range the ingnitor switch is divided in two, between left and right sides. Thanks
#2 Derik
Derik
    Sōhei
  • 220 posts
  • Flavorite Brew:coors light
Posted 15 February 2012 - 01:48 AM
Is it showing spark at all? And only the one burner isn't lighting???
#3 RegUS_PatOff
  • 30,249 posts
Posted 15 February 2012 - 08:36 AM
... the Front Right Burner is not lighting,
... not lighting ?
is it sparking ?
Does it Spark when any other Burners are turned ON ?
MODEL NUMBER ?
#4 Brooke Falconer
Brooke Falconer
    Ikkō-ikki
  • 40 posts
Posted 15 February 2012 - 09:56 AM
JGS8850BDS17, It will light with a lighter, spark is hard to see. It sparks when you turn on the back burner. I switched the ignitor out, and it still did not light, so I would think it would be safe to say the problem does not lay with the spark ignitor (ceramic electrode?)
#5 RegUS_PatOff
  • 30,249 posts
Posted 15 February 2012 - 11:37 AM
... spark is hard to see.
... It sparks when you turn on the back burner.
so it's a weak Spark when either Burner is turned ON ?
On that model, each Burner Knob should only Spark one Ignitor.
Could be a weak Spark Module OR the High Voltage wire to the Ignitor (degraded / grease, etc)
You could try swapping that Spark Module output with another output.
#6 Brooke Falconer
Brooke Falconer
    Ikkō-ikki
  • 40 posts
Posted 15 February 2012 - 06:47 PM
So is there anyway of testing either the switch (Repair Clinic part 1189190 OR manf # 74011648) or the Spark Module (Repair Clinic part 696058 Manf # 71002783) before you dismantle the entire cooktop and switch around parts. Even then, is it by the process of elimination for the spark module?
Thanks for your help by the way.....
#7 RegUS_PatOff
  • 30,249 posts
Posted 15 February 2012 - 06:51 PM
... is there anyway of testing either the switch ... before you dismantle the entire cooktop and switch around parts.
... is it by the process of elimination for the spark module?
1) I don't think so ..
2) yes
#8 Brooke Falconer
Brooke Falconer
    Ikkō-ikki
  • 40 posts
Posted 15 February 2012 - 06:55 PM
Well Bullocks! That sucks! Just what I didn't want to do!
Thanks again, I'll post how it went
  • 24,289 posts
Posted 15 February 2012 - 07:53 PM
JGS8850BDS17,
Topic title edited.
