Bosch WTMC6500UC/01 dryer door catch broke off
DO I NEED TO REPLACE ENTIRE D
8 replies to this topic
#1 MARTINOB
MARTINOB
  • 5 posts
  • Flavorite Brew:coffee
Posted 13 February 2012 - 08:36 AM
Hello,
Was frustrated trying to get this dryer running again over the weekend and snapped off the tab for the door open / closed sensor. This is a little plastic tit located on the inside panel of the swinging door I have a screw in their now to fool the sensor and get the laundry done, but it isn't stable and I would like to replace the entire inside panel of the dryer but I can only find a part number for the whole door. Any help would be appreciated.
Martin OB
#2 MARTINOB
MARTINOB
  • 5 posts
Posted 13 February 2012 - 10:13 AM
Hello,
The plastic interior door liner from part number #241824. The small tit that actuates the door sensor switch # 424040 snapped off, I would prefer not to buy the whole door assembly. This would anger mama san and cut into the coffee fund.
MartinOB
#3 MARTINOB
MARTINOB
  • 5 posts
Posted 13 February 2012 - 02:29 PM
http://www.repaircli.../241092/1103599
#4 MARTINOB
MARTINOB
  • 5 posts
Posted 15 February 2012 - 03:13 PM
Do I need to replace entire door?
Snapped the door pin off of the Bosch WTMC6500UC/01 dryer. Image here:
http://www.repaircli...=WTMC6500 UC/01 I really can't afford the whole door is there a repair kit, right now I have a screw in there which tricks the door sensor, but it isn't stable.
Martin ob
    Shōgun
  • Master Samurai Tech
  • 31,400 posts
Posted 15 February 2012 - 09:21 PM
Post a photo that you took of your dryer showing what's actually broken on your dryer.
#6 MARTINOB
MARTINOB
  • 5 posts
Posted 17 February 2012 - 07:41 AM
OK, Here are photos of the actual dryer door.
Thank you.
http://s1166.photobu...13/MartinOB357/
#7 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 February 2012 - 12:18 PM
oohh, now I see ...
    Shōgun
  • 31,400 posts
Posted 17 February 2012 - 04:55 PM
That's a molded piece, the little plastic tit is part of the mold. You'll need to either replace the entire plastic panel or perhaps you can rig something with a shaped piece of plastic, gorilla glue, and some imaaaaaagination. :blinky:
#9 RegUS_PatOff
  • 33,588 posts
Posted 17 February 2012 - 05:25 PM
OR possibly drill, insert a screw / small bolt from the other side ...
