Maytag LDG7304AAE Dryer Motor Rewiring
8 replies to this topic
#1 BobNJ
BobNJ
  • 10 posts
  • Flavorite Brew:Homemade Imperial Russian Stout
Posted 15 February 2012 - 03:58 PM
I am replacing the motor in my dryer (among several other parts). The new motor has a different wiring block. Part of the instructions do not make sense to me (Instruction Sheet W10408722 Rev A 4/11).
The insturctions indicate I should connect the red wire to the new motor at terminal #5 and the blue wire should be connected to terminal number 1. But in the last column of the table of connections (in a cell for red and blue), it says to "Reterminate the Red and Blue Leads in the same 1/8" Insulated Terminal and Connect to Switch Tab 5". It sounds like I am being instructed to attach blue to both #5 and #1. How do I do this? Should I apply Quantum Mechanics?
The red wire comes from the console above. The blue wire is actually a white wire from the console above joined with a blue wire from the door switch into a terminal which was connected to a blue-dot labled terminal on the old motor. I am assuming that this is what they mean by the "blue" wire.
All of the other colors match the instructions and are connected and accounted for.
I tried to post a picture of the section of the instructions I am referring to, but it did not seem to take.
I just went to the hardware store and a widely known electronics store and neither place had 1/8" terminals. They do have 3/16" inch so I guess I could use those or just crimp down the 1/4" terminals and set up a blast radius around the laundry room.
Edited by BobNJ, 15 February 2012 - 05:05 PM.
#2 RegUS_PatOff
  • 30,190 posts
Posted 15 February 2012 - 08:10 PM
Maytag LDG7304
missing (3) characters at end of model number
what's the new Motor part number ?
#3 BobNJ
BobNJ
  • 10 posts
Posted 15 February 2012 - 08:17 PM
Gosh darn it! How did that happen? :)
LDG7304AAE
The RepairClinic invoice has Item # 2118676 and Part # W10410999.
I did get 3/16" terminals but they are not insulated as specified on the motor instructions. I'm hoping that is not a problem. None of the original terminals are insulated.
#4 RegUS_PatOff
  • 30,190 posts
Posted 15 February 2012 - 08:53 PM
... I tried to post a picture of the section of the instructions I am referring to, but it did not seem to take.
there's an upload size limit here ..
try uploading somewhere else, then post the link here
  • 24,203 posts
Posted 15 February 2012 - 09:32 PM
LDG7304AAE
Topic title edited.
#6 BobNJ
BobNJ
  • 10 posts
Posted 15 February 2012 - 09:44 PM
It's only 111 KB. The web site says the limit is 200 KB.
Here is a link.
http://i39.tinypic.com/ouo5j5.jpg
Curious as to why the web site is on London time.
#7 kdog
    RoughShod
  • 7,428 posts
Posted 15 February 2012 - 10:34 PM
Click on your name at the top r.h. of page, from the ensuing dropdown, click on "settings' and adjust to the appropriate timezone.
Hey, Brutha, can you spare a dime for a cuppa joe ? http://web.me.com/zenzoidman/kdog/
Le Chien Rouge
#8 RegUS_PatOff
  • 30,190 posts
Posted 15 February 2012 - 10:58 PM
after studying the "old motor" diagram and the "new motor" diagrams
For your model, it looks like you should ignore that last column
Don't connect 1 to 5
#9 BobNJ
BobNJ
  • 10 posts
Posted 16 February 2012 - 05:22 PM
I did as you advised and it seems to be working when I ran it for 30 seconds empty. Motor/drum turned, flame came on, door buzzer buzzed. All systems go (knock on wood). Thanks for the help!
