Whirlpool DU1055XTSS1 Flashing LED at Pots and Pans button and will not run
5 replies to this topic
#1 vineman
vineman
    Yamabushi
  • Chief Appliantologist
  • 96 posts
  • Flavorite Brew:Priorat
Posted 16 February 2012 - 10:23 AM
Looks like an error code flashing on Pots and Pans selection. The dishwasher will not run. It is not the control board. I put a new one in and the same problem exist with no improvment. Any idea what could cause this problem?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 16 February 2012 - 10:36 AM
from the tech sheet:
PROBLEM: Won’t Run and LED Above Key(s) is Flashing Rapidly
Short circuit(s) in keypad or in control’s input lines that read the keys.
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a “dead” keypad / console)
indicates one or more key switch lines are stuck or shorted on either the control or the keypad.
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control’s response:
➔If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
➔If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
#3 vineman
vineman
    Yamabushi
  • 96 posts
Posted 16 February 2012 - 05:42 PM
I will try the test and let you know...Thanks!
    Shōgun
  • Master Samurai Tech
  • 30,033 posts
Posted 17 February 2012 - 10:30 AM
This is almost always a shorted keypad on the touchpanel ==> Touchpad and Control Panel
#5 vineman
vineman
    Yamabushi
  • 96 posts
Posted 17 February 2012 - 05:09 PM
Ran the test it was conclusive. The control panel was bad. RepairClinic has it in stock, thanks for all the help!
#6 RegUS_PatOff
  • 33,588 posts
Posted 17 February 2012 - 05:32 PM
... control panel was bad.
Touch panel ?
How to test the keypads on the touchpanel of a Whirlpool dishwasher
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 17 February 2012 - 11:43 AM
If you have a flashing light above one of the keypads on your Whirlpool dishwasher, the keypad may be shorted. This does not apply to the Clean Light blinking in a sequence of seven blinks, pause, seven blinks, etc.; more on that...
Read Full Entry →
