Frigidaire FRS26ZRF, side by side, ice build up in bottom of freezer section
9 replies to this topic
#1 pojo60
pojo60
  • 1 posts
  • Flavorite Brew:Dr. Pepper
Posted 16 February 2012 - 11:37 AM
Hi first time user here.
My Frigidaire refrigerator, side by side unit, Model# FRS26ZRF is building up ice in the bottom of the freezer compartment. Looks like it may be coming from the compartment that contains the coil (evaporator section?). The temp is still okay as the frozen goods are staying frozen. The other side of the unit (refrigerator) is operating normally. Is this a plugged line, defroster failure or something else?
Many thanks,
pojo60
#2 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 16 February 2012 - 11:52 AM
Most likely a plugged defrost drain line.
You will have to turn the unit off to defrost the drain line completely.
A hair dryer might assist you enough to melt the ice in the hole.
#3 RegUS_PatOff
  • 30,690 posts
Posted 16 February 2012 - 12:19 PM
... Most likely a plugged defrost drain line.
OR a clogged Drain Line... (peas, corn, etc)
Drain Line at bottom of # 62 inside freezer
#4 Dr Freeze 40
Dr Freeze 40
    Ikkō-ikki
  • Chief Appliantologist
  • 20 posts
  • Flavorite Brew:Miller
Posted 16 February 2012 - 01:08 PM
with all the plastics in refrigerators now ,suggest using a portable steamer for defrosting or removing ice . they are cheaper than replacing a melted fridge linner :samurai:
"A Problem is just a Solution waiting to happen"
#5 kdog
    RoughShod
  • 7,433 posts
Posted 16 February 2012 - 10:41 PM
Steamer
#6 RussTech
RussTech
    Kohai
  • 304 posts
  • Flavorite Brew:Heineken
Posted 17 February 2012 - 12:55 AM
Steamers seem like they would generate too much additional liquid water. I always see you guys mention them, but I've yet to use one. Heat gun has always worked fine for me!
#7 kdog
    RoughShod
  • 7,433 posts
Posted 17 February 2012 - 08:29 PM
I said the very same thing, until I got one ..............
Can't imagine cleaning/melting out a drain without one anymore - also very handy cleaners !
#8 Derik
Derik
    Sōhei
  • 227 posts
  • Flavorite Brew:coors light
Posted 17 February 2012 - 10:35 PM
Hair dryer works great for me, works fast too!!!
#9 Derik
Derik
    Sōhei
  • 227 posts
Posted 17 February 2012 - 10:43 PM
Also use a co2 tank with foot long flexible copper line for removing plugged debris!!! Only 1/4 round fits right down in drain hole for blast off!!!!!
  • 24,698 posts
Posted 18 February 2012 - 01:17 PM
If I could like it twice, I would! :dude:
I carry a portable air tank with a rubber-tipped nozzle for this.
