Maytag Bravo washer MVWX600XW0 makes clacking noise but won't run
#1
Posted 17 February 2012 - 12:24 AM
Appartnetly the washer thinks, its doe what it was programmed to do.. Goes throught all.. NO CODES! Clothes are still dirty and soping wet. Now, I started the washer with it tipped back, there is a motor and belt. During this Buzz, GRRR GRRR the motor moves the belt and the washer pully forward then back then forward and back.. and thats it done. I did not wait for it to go to wash cycle to start. I knew something was not right with it. I do not get any codes. I have tried to hold the button down for 3 and 4 seconds releasing it for 3 and 4 seconds what I seen on youtube.com to get into the washers memory codes, but I cant seem to get in there using that processes.
Underneath on soundpadding, there is dusting from the belts, and the plastic cover seems to have melted spots, I can post pictures and a video soon. Once I have more time to get down there and work on it.
I have tried to look for a teardown, but I find only ones with direct drive.
Do you have a idea what it might be? Motor bad? or Transmission (gearbox) bad? a switch? little lost.. Next I guess I will try disasemble to see what looks bad worped or something.
#2
Posted 17 February 2012 - 12:35 AM
ill help figure it out
#3
Posted 17 February 2012 - 12:58 AM
#4
Posted 17 February 2012 - 09:52 AM
Also,
The magnetic reed switch in the lock mechanism could be bad.
Set the nachine for SPIN and see if it will spin.
#5
Posted 17 February 2012 - 11:43 PM
For that price, a new one but I am not going to buy a new one. Take this apart piece by piece and see what looks wrong. Othere than no moving, it does what its programmed to do.. If a put a very small load water fills just above if I put a large load water fills just above.
With what things are made of now, Metal on plasic.... should not be too hard to find what is broke. How hard can this be? I have taken a car motor apart and put it back together and I have taken computers and laptops apart and put them back. Seems pretty much pieces and parts..
I do know it is not the locking mec. on the door.
#6
Posted 17 February 2012 - 11:47 PM
#7
Posted 18 February 2012 - 07:55 PM
#8
Posted 19 February 2012 - 05:14 PM
Tips for freeing a stuck tub in these washers ==> http://fixitnow.com/...-ol-error-code/
The Bravos model MVWX600XW0 of topic is not that kind of Bravos. It's a VMW mechanism, the basket does not float and requires a spanner wrench to remove.
#9
Posted 19 February 2012 - 05:56 PM
#10
Posted 20 February 2012 - 01:19 PM
Domo, Dado-- I didn't pull the diagrams on this one before I posted.
James, I have several posts on this washer in my blog that you'll want to peruse:
Whirlpool Vertical Modular Washer (VMW), United Servicers Regional Training in Albany, NY (especially the comments on this post)
How to enter diagnostic mode, decipher error codes & check the control board in a Whirlpool Vertical-Modular washer (VMW)
How to replace the lid switch in a Whirlpool VMW washer
- kdog likes this
#11
Posted 21 February 2012 - 08:44 PM
#12
Posted 22 February 2012 - 09:03 PM
#13
Posted 08 May 2012 - 06:30 AM
- mondo760 likes this
#14
Posted 09 May 2012 - 01:27 AM
Also tagged with one or more of these keywords: Not Spinning, Not Agitating
