Learn how to be your own tech line…
Sign in to follow this
Followers 0
tracerracer
My LG wm0532hw front load washer is not spinning or draining....... No codes
10 posts in this topic
Also, throwing NO codes....... I have run the QC test mode (unplug for 20 mins or so to 'reset', then press the spin speed/soil level ...... Then X amount of pressing the start/pause button, to get it to do Y) In that, it will not spin or drain, no noise........... Any suggestions to help me 'narrow down' what is the problem (or did I 'lose' the pump AND something else simultaneously?) It does make a 'humming' noise (while not 'doing anything' during the cycle)
<<<It does make a 'humming' noise (while not 'doing anything' during the cycle)>>>
Does water fill/enter the tub?
If yes---unplug washer
Remove the rear/back access panel
Remove the 17mm bolt from the motor assy
Pull off the ROTOR ASSY (large round silver part of the motor)
Examine the *splines* on the ROTOR. If *stripped/worn*---replace the ROTOR ASSY.
Add *threadlocker* to the 17mm bolt when re-installing.
Could b plugged pump???
<<<Could b plugged pump???>>>
Usually an "OE" error will be displayed if a *no-drain* condition occurs.
Occassionally---a DRAIN MOTOR will function---but at a reduced capacity (or intermittently).
If this washer is at/near 5 years old---it could very well be a failing DRAIN MOTOR.
Some WM0532 washers *did* have a problem with the ROTOR becoming loose and this causes the spline/teeth to become stripped/worn on the ROTOR (this occurs more often on WM0642 models though).
In many cases---the complaint will be...
"The washer made a lot noise during tumble or spin and the clothing is wet at the end of the cycle".
More...
If water remains in the tub---the washer will NOT enter the spin cycle.
Try draining any remaining water from the tub---through the small/black drain tube at the lower left corner on the front of the washer.
Turn on the washer.
Press the SPIN SPEED button---select the highest spin speed setting
Press START.
Did the tub enter high speed spin when "9 minutes" was displayed?
If yes---replace the DRAIN MOTOR.
http://www.repaircli...Number=WM0532HW
Edited by john63
Ok, sorry it's been so long (and thank you for your answers) Rotor off and is good, I think it is the drain motor (as described) where is that on this machine?
Once again, sorry it's taken me so long to get back to you and thank you for replying ........... I believe strongly that it is the pump.......... I now have one ordered........ Thank you again for your time and answers..................T
Sounds like a plan.
Let us know of the results.
Good Luck
I finally received the new drain pump and replaced it.... What it turned out to be , was HAIR in the pump.......... My DD has very long hair and it got 'wound up' into a rock like 'plug' in the pump (didn't find it until replacing it).............. It has taught me a lesson, I will be checkin' my pump at least twice a tr to try and avoid this again........ Thank you for all of your suggestions
Glad you got it fixed,and got to learn bout your washer!!!! Good job!!!
Followers 0
