Learn how to troubleshoot like a Master Samurai Tech...
tommytech
asko t761 dryer
4 posts in this topic
i got an asko t761 main board has been replaced,giving me fault codes in languages other than english. followed manual to change to english but does not respond. new control board has jumpers on back,but cant figure what terminal to put them on or leave as is
ok,flipped a couple jumpers,got display in english. runs approx 2min- gives fault code of overflow,but this model is NOT a condensate type dryer. gotta believe the new board is defective or needs to be programmed. any ideas?
I got an asko that had board replaced because old board had no display and would not t urn power on.Tech went out and replaced both m boards,now its giving fault codes in swedish only. there are pin connector/jumpers on back,and when i switched one over the display now reads in english and is giving me a fault code of "overflows" which is for a condensate dryer, but the model 761 is not a condensate dryer. gotta believe either the board is defective or needs programming. i downloaded a tech manual from this site but no info about this issue.asko wont help with tech issues.
Topics merged.
