oldschoolmc
Whirlpool WED9200SQ1 dryer - no heat
2 posts in this topic
This dryer runs but does not heat. the small thermofuse will not show any ohms between the terminals. Could this be the problem?post-68254-0-86894400-1329935137_thumb.j
Thermal Cut Out Fuse Kit
Item # 1175772
Thermal fuse and high limit thermostat kit
Manufacturer Number 280148
Large-Part-Image?imgID=1022512&locID=3399
Yeah that sounds like your problem! Did u check blower housing and vent to clear all debris so you have good airflow??? If not do that and get the thermal cut out kit from repair clinic and you'll be back in action!!! To temporarily fix or confirm diagnosis you can bypass fuse by putting the two wires together but besure to not let them touch anything else cuz there is 115volts threw it!!! Let us know outcome
