Whirlpool Duet GHW9250MT2 Washer won't run top cycles
F11 wont run top cycles
6 replies to this topic
#1 horse
horse
  • 4 posts
  • Flavorite Brew:Nordeast
Posted 24 February 2012 - 08:28 PM
About 2 months ago when got the F11 code, it eventually started working again. It then would lock the door and we would run the drain/spin cycle and it would unlock. Then we would unplug it and it would work but made beeps during cycle. Now it wouldn't run the top cycles, it lights up the mirror cycles on the bottom of the dial but it works. Just wish I knew if a new or refurbished CCU would fix. Thanks for any suggestions. I have unplugged the wiring harness at CCU and plugged back in and didn't help.
    Shōgun
  • Master Samurai Tech
  • 30,905 posts
Posted 24 February 2012 - 08:52 PM
This is the catch-all communications error code. Disconnect/reconnect the harness connectors on the door latch assembly. Use some conductive grease on the connections.
There's no risk in ordering parts thru this site because you can return any part for any reason for one year.
Door latch assembly part link ==> http://www.repaircli...mber=GHW9250MT2
#3 horse
horse
  • 4 posts
Posted 24 February 2012 - 09:04 PM
The door is not the problem now, it is not beingable to run the Normal cycle. Is the door latch connection causing this? Thank you.
#4 horse
horse
  • 4 posts
Posted 25 February 2012 - 10:03 AM
I messed with the harness connections, pushed on solder connections on dial circuit board and the other cycles started working last night. This morning it was back to only the bottom cycles working. I don't know what I did, maybe the power off while messing with the boards did it. I keep at it and only do one thing at a time and see if I can isolate the problem. Thanks for any help you can give.
    Shōgun
  • 30,905 posts
Posted 25 February 2012 - 10:39 AM
#6 horse
horse
  • 4 posts
Posted 05 March 2012 - 12:15 PM
Noticed that I could make Normal cycle light up if I turned the dial a touch. Put a little electrical contact cleaner onto dial circuit board and problem resolved. Thank you for your help.
    Shōgun
  • 30,905 posts
Posted 05 March 2012 - 01:07 PM
:thumbsup:
