Frigidaire, FDE336RES2, Dryer, Start Issues
frigidaire dryer starting start button timer
3 replies to this topic
#1 sighBorg67
sighBorg67
  • 2 posts
  • Flavorite Brew:Bass Ale
Posted 24 February 2012 - 09:10 PM
Hello, I have a Frigidaire FDE336RES2 model clothes dryer that has exhibited a progressive series of issues involving failure to start and/or faulty starting.
First - the starter button itself began to fail. To get it to start, had to press it more than once, or hold it down longer than usual. Other than that, dryer would run fine.
Second - within 1-2 weeks of first symptom, the dryer began to start simply by turning the timer knob. Opening the dryer door would now NOT turn dryer off. In order to turn the unit off, the timer knob had to be turned to 0 (zero). Otherwise, dryer working as normal.
Third - Currently (w/in days of symptom 2), dryer will make 'running' sound when the timer knob is turned, and will heat up normally, but now the drum no longer turns - whether door open or closed.
If this is the motor going bad, maybe it is time to face the music and buy a new dryer (unit is eleven years old). But - if it may otherwise be repaired, I would be happy to do it.
Any Ideas?
"Music is the best"
  • 24,279 posts
Posted 24 February 2012 - 09:57 PM
Let's start with the third problem you listed for this Magical Pig:
This sounds suspiciously like a broken belt. Open the door and try to rotate the drum each way. If it turns easily in both directions, then you probably have a broken belt ==> Drive Belt
The 1st and 2nd problems could both be a bad start switch. You can check this with your meter to verify ==> Start Switch
#3 sighBorg67
sighBorg67
  • 2 posts
Posted 24 February 2012 - 10:21 PM
I will check all of this tomorrow morning.
Thanks a million for the quick response, and goodnight Samurai Appliance Repairman, wherever you are!
#4 RegUS_PatOff
  • 30,242 posts
Posted 24 February 2012 - 11:54 PM
... To get it to start .. starter button .. had to press it more than once, or hold it down longer than usual.
... dryer began to start simply by turning the timer knob
... Opening the dryer door would now NOT turn dryer off.
... Currently ... dryer will make 'running' sound when the timer knob is turned, and will heat up normally, but now the drum no longer turns
1) bad Start Button
2) bad Start Button
3) bad Door Switch (opening Door should disconnect Neutral to Motor)
4) broken Belt
many problems ... check to see if there's a lot of lint inside the Dryer, Switches, Motor ....
Also tagged with one or more of these keywords: frigidaire, dryer, starting, start button, timer
