Maytag Dryer MEDC200XW0 Overheating
5 replies to this topic
#1 Saltine
Saltine
  • 3 posts
Posted 25 February 2012 - 01:37 PM
Dryer trips after operating for a short time. Cleaned and replaced vent. Operates fine on no heat. Replaced cycling thermostat. Checked heater coil for ground, satisfactory/no ground. Airflow seems adequate. Heater coil showing 10 ohms, seems low? Thanks.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 25 February 2012 - 03:09 PM
Dryer trips...
what "trips" ?
#3 Saltine
Saltine
  • 3 posts
Posted 25 February 2012 - 05:01 PM
Shuts off and needs to cool down.
#4 RegUS_PatOff
  • 33,588 posts
Posted 25 February 2012 - 06:41 PM
stops Tumbling ?
sounds like a bad Motor (when warm)
try removing the Belt, and turn the Motor Shaft by hand.
Does it turn easily, smoothly ?
http://www.repaircli...sp?R=154&N=2584
#5 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 852 posts
  • Flavorite Brew:yeunling
Posted 26 February 2012 - 08:11 AM
when it shuts down have you checked to make sure there is still 220 at the outlet, i have seen weak breakers cut power and restore it when cooled off without having to be manually reset. that model seems pretty new to be needing a motor already, not that it isnt possibly, just look for other causes first
#6 Saltine
Saltine
  • 3 posts
Posted 26 February 2012 - 12:07 PM
Motor spins, makes scraping sound, and stops turning. Not siezed, but not spinning great. Blower wheel did not want to come off. Motor gooed possibility as I never saw any temperature switch open, despite red hot element and hot heater housing.
